Re: [Digital BW] Digest Number 1172
2002-12-08 by Bruce
on 12/7/2002 5:45 PM, DigitalBlackandWhiteThePrint@yahoogroups.com at DigitalBlackandWhiteThePrint@yahoogroups.com wrote: > > Message: 24 > Date: Sun, 08 Dec 2002 01:14:20 +0000 > From: "chris schiller" <rhellics@...> > Subject: Nikon 8000 Scanner Failures > > > > About a month ago I received my new Nikon 8000 scanner. At first I was > delighted. The scanned images were wonderful. But soon the scanner started > giving "film holder not recognized" errors. Trying other film holders gave > the same result. The problem was intermittent. I could cycle power and it > would work fine. But then the scanner started slipping and jerking the film > holder as it initially scrolled it in, sometimes accompanied by errors, > sometimes not. Soon it started slipping and grabbing during scans. The > resultant scans showed that, obviously, the holder was left stationary and > then slipped toward the correct position. Stationary, slip-clunk, > stationary, slip-clunk. A slight pressure on the film holder was enough to > overcome whatever trouble the scanner was having gripping the film holder. > Soon, however, the scanner started making loud clunking noises as it "did > its business" after the dust cover was slid open and closed. The film > holder slipping and clunking got worse. Obviously there was a major > problem. > > I called Nikon support, and very quickly they came to the conclusion there > was a problem and told me to send it in for warrantee work. After 2 weeks! > Fortunately Adorama let me send it back to them for an exchange ($70 > shipping charges). > > I'd expect more from a $3000 instrument, and a Nikon too! > > So I received the new scanner yesterday (checking the serial number to make > sure it was a different one!) > > From the first time I turned it on and tried to insert a film holder, I got > the same problems! No manner of reinstalling the software, changing the > firewire card, or recycling power would make it work without the same > problems as the other scanner. They started as intermittent and then got > worse, just like the first scanner. Then soon the loud clunking noises > started. Precision optical instruments should not make loud, sharp clunking > noises the first day you turn them on! > > Once is a possible rare assembly problem or defect. Twice is a trend. Has > anyone else had these problems with a Nikon 8000? > > If Adorama will let me, I am going to exchange it for the Minolta Dimage. > Perhaps Nikon has gone the way of HP: once producing products you could > trust, and now just gluing a nameplate on something subcontracted to dodgy > faceless companies somewhere. > > Chris > Chris, When did you return your scanner? I received mine in late September I think. It has the exact same symptoms as yours did. Mine came from Samys camera in LA though. I guess I'd better exchange it while it is under warrantee. -Bruce
