How to get bright white with quadtone ink set.
2002-12-17 by jbach347 <joebach@pacbell.net>
I am considering using the MIS VM hextone inkset in an Epson 2000 and Epson archival matte paper.
However, my first question relates to any quad or hextone ink set.
1. With a quad or hextone inkset how does one get bright whites in a print, a white brighter than the whiteness of the paper it is printed on?   All the inks are shades of black, so how can one get a white that is brighter than the paper printed on?
2. What is a good archival paper that is whiter than the Epson archival matte paper?
3. Is there any metamerism using MIS quad or hextone inks on Epson archival matter paper?   Note: Using MIS color inks, I don't see metamerism on Epson archival matte paper.  I only see the metamerism if I print on a glossy paper?
Re: How to get bright white with quadtone ink set.
2002-12-17 by Shilesh Jani <shilesh.jani@smith-nephew.
Joe,
You cannot get a print any brighter than the paper - period.  The
brightest paper I have encountered is Eclipse Satine Bright White.
It is 100% cotton rag (so it has good "archival" properties).  You
can get the paper at inkjetgoodies.com.  But you may want to hurry,
because the supplies are limited.  Other bright white papers are Red
River Premium Matte and Legion Photo Matte.  But both of these papers
are wood derived (acid free, but not "archival").  All of these
papers print very well with MIS VM inks; you will have to tweak the
curves for each paper.
Regards.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jbach347
Soft Proofing w/ ImagePrint Profiles
2003-01-04 by Eddie Gilbert
Is there anyone on this list who is using ColorByte's ImagePrint RIP
(Mac OS X version), who has been successful in getting Photoshop to use
the ImagePrint-supplied printer profiles for soft proofing?
I have been soft proofing against my prior self-created Monaco Proof
profiles just fine, but Photoshop doesn't even want to list the
ImagePrint profiles in the Proof Setup Profile selection list (likewise
w/any other profile selection list; i.e., Assign Profile, Convert to
Profile, etc.).
Is it even conceivable that such a "professional" RIP would not utilize
printer profiles that Photoshop can soft proof against?
If anyone is soft proofing with these ImagePrint profiles with success,
I would very much appreciate your help...
/eddie
Re: Soft Proofing w/ ImagePrint Profiles
2003-01-04 by Mitch Alland
Eddie:
OSX has an application called "ColorSync Utility" which is in the
Utilities folder of the root Application folder. Run the "Profile First
Aid" of the ColorSync Utility: this will fix the ColorByte profiles so
that they show up in Photoshop. However, in order for the ColorByte
profiles to show up in the Profile First Aid list, you may have to make
as alias of the IP "Color" folder, and place that alias in one of the
ColorSync profiles folders on your machine.
After the ColorByte profiles show up in Photoshop, I recommend, as
described in pages 371-378 of Real World Photoshop 7, that you
"Duplicate" the image in Photoshop and apply the SoftProof to the
duplcate and the apply adjustment curves to the original image until
the latter looks as much as possible as the duplicate. Then print from
the original image with the adjustment layers. Then you want to group
these adjustment layers into an adjustment set, and save the adjustment
set. The adjustment set becomes your basic "targeting" adjustments for
all images printed by this printer. I have found that I can use the
same adjustment set for most of the prints to be made on my 7600, but
some images do require further special adjustments.
--Mitch/Bangkok
2003-01-05 by Mitch Alland
Eddie:
--Mitch/Bangkok
