Replicating selenium tones
2002-12-19 by lomoeye <james.stogdill@verizon.net>
I print with the piezo selenium ink set.  I have set up a custom dot
gain curve so that my output very closely matches what I see on my
monitor in terms of density.  However, I'd like to be able to post
digital versions of my work to the web that replicate the selenium
tone of the final output.
I've tried scanning the final print on a flatbed but I'm really not
happy with the results.
Has anyone out there developed photoshop curves or some other method
to slightly tweak the RGB values of a B+W image so that it will
appear on screen with the subtle selenium tones of the printed
output?  Thanks,
js
Re: Replicating selenium tones
2002-12-19 by Shilesh Jani <shilesh.jani@smith-nephew.
Try the following:
Convert the grayscale image to RGB.  Do a color adjustment.  Add
magenta in the shadows, and blue in the highlights. Tweak the color
sliders until you get a decent match.
Good luck.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lomoeye
<james.stogdill@v...>" <james.stogdill@v...> wrote:
> Hi,
dot
method
> output?  Thanks,
> js
2002-12-19 by jim hayes <jimhayes@frii.com>
The below may be the best way, but I used to just put a  duotone mode
on it in photoshop. I've used both canned ones and customised ones.
Haven't done it in years, maybe since version 3 or 4 so don't know
what they have now in the duotone folder. I used to be happiest with a
quadtone file rather than a duo or tritone file.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani
<shilesh.jani@s...>" <shilesh.jani@s...> wrote:
> Try the following:
> Good luck.
> > Hi,
> dot
not
> method
> > output?  Thanks,
> > js
