Re: [Digital BW] Re: Problems with my 1160
2002-12-19 by Barry Kelsall
Steve, the reason you check the nozzles with OEM Epson carts is to eliminate variables - if you still can't get good nozzle checks with Epson carts, then you have a problem in your print head (which. you attack with various flushing/soaking strategies). If you get good nozzle checks with Epson carts, but the problem returns with your aftermarket inks, then you have a problem with the cart/ink-delivery system. You may need a new cart. Are you using CIS/CFS? You may have a partially obstructed tube. The MIS co-solvent black is suseptible to drying out inside the tubing if allowed to sit for periods of time. good luck, -BK ----- Original Message ----- From: <stevenr@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Thursday, December 19, 2002 3:08 AM Subject: [Digital BW] Re: Problems with my 1160 > Hey Martin, > > I cleaned the bottom of the head with towels wet with Windex, which > seemed to work well. Thanks. > > > I am still not getting a good nozzle check. I have heard of soaking > the parking pad with Windex, and leaving it over night, but why should > I reinstall the Epson cartridges, and then run them through the nozzle > cleaning cycle? Will the epson inks help dissolve the clogged MIS > inks in the head? > > Thanks again > > Steve > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Wesley" < > mwesley250@e...> wrote: > > Steven, > > > > Sounds like the underside of the print head may be dirty and in > need of some > > cleaning. > > > > First you must release the print head so that you can manually move > it from > > side to side. With the 1160 you should be able to push the > cartridge change > > button and once the head assembly is in the cartridge loading > position > > unplug the printer. > > > > A common way to clean the bottom of the head is to place folded > paper > > towels, cloth or sponge cloth in the path the head travels that are > wet with > > Windex, ammonia & water, or rubbing alcohol & water. Then manually > move the > > head back and forth over the wet material to clean off any gunk > (dried ink > > and paper fibers). Change the paper towel a couple of times. > > > > When you feel you have gotten it clean, then move the head to its > normal > > parked position all the way to the right before you plug the > printer back > > in. > > > > If you are still not getting good nozzle checks then I would try > installing > > some Epson cartridges and doing nozzle cleaning cycles. > > > > Martin Wesley > > > > http://www.borderless-photos.de/guests.html > > > > > > > > ----- Original Message ----- > > From: <stevenr@m...> > > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Sent: Tuesday, December 17, 2002 6:49 PM > > Subject: [Digital BW] Problems with my 1160 > > > > > > > Help, > > > > > > I am having problems with my 1160. I started having problems > getting a > > > good nozzle check (I never do). At the same time ink track marks, > from > > > the rollers, started to appear on my paper. I cleaned the inside > of > > > the printer and run several sheet of paper through until the > paper came > > > out clean. But, as soon as I cleaned the heads and did a nozzle > check > > > and ink tracks would reappear. I could never get a good nozzle > check. > > > > > > If the nozzles are clogged will it spray ink all over the inside > of the > > > printer? > > > > > > Thanks > > > > > > > > > > > > > > > Please visit the Group Homepage to check the Files, Bookmarks, > Polls and > > other resources as they are often being updated. The page is at: > > > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > > > If you wish to receive no emails or just a daily digest, or you > wish to > > unsubscribe, please edit your Membership preferences by visiting > this same > > page. > > > > > > Please follow these basic guidelines: > > > - Include your full name with your message. > > > - Include the address of your website, if you have one. > > > - As threads develop, trim off excess portions of earlier > messages to keep > > them short. > > > - As the topic of a thread changes remember to change the subject > header. > > > - Good manners are required at all time. No personal attacks or > > &amp;quot;flames.&amp;quot; > > > - Complete your Yahoo profile. > > > - Before posting a question, search the message archives and the > various > > resources on the homepage. > > > > > > > > > > > > > > > Your use of Yahoo! Groups is subject to http:/ > /docs.yahoo.com/info/terms/ > > > > > > > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > >
