Re: Silverfast 6 Update
2003-01-01 by Chuck Jones
Date: Wed, 01 Jan 2003 07:38:20 -0000
From: "frankg_photo <fh.gross@...>" <fh.gross@...> Subject: Silverfast 6 I just downloaded/installed Silverfast 6.01 upgrade (PS plug-in ver.) for my Polaroid Sprintscan 120. I just bought the unit used with an earlier version(5.2) of Silverfast. In the original earlier version (5.2) there were 2 programs within it that were listed under the PS>File>Import menu - the regular Silverfast Ai and the HDR. Now with the version 6 download I only have one program listed "Silverfast (Polaroid)" - is this the way it is meant to be or did I select the incorrect one to download/install ? Also, is the setup and it8 calibration the same or different to the 5.2 version ? thanks, frankg Frank, Silverfast decided to "split" the update in version 6 into two parts. And they do charge you for EACH update. You got the Ai update, that operates your scanner. This is probably the one you want. The HDR is for using Silverfast to adjust disk files. I didn't bother with the HDR update either, as I see no advantage over Photoshop, and the cost is substantial. Warmest Regards, and Happy New Year! Chuck Jones
