Tidbits from Epson Print Academy
2003-01-07 by sanfo2003 <SandyCornelius@cox.net>
Attended the Epson Print Academy last weekend. It was a several hour
presentation validating inkjet printing (especially using Epson
equipment)that was peppered with valuable tidbits. I found the
seminar was a bit basic and if you're really into this forum then you
would probably find it a bit basic too. The question and answer
period at the end was most valuable and the speaker stayed as long as
necessary to answer any and all questions -- this ran an additional
two hours since there were maybe two hundred people there (in
Phoenix). Worth the money in my opinion. Really nice, knowledgeable
and helpful folks.
Here's the big one I learned about the 2200: print all your B&W stuff
in the RGB mode -- don't, I repeat, don't convert to greyscale in
Photoshop before printing. It has to do with the way the 2200 driver
uses inks in RGB vs. Greyscale.
So, I immediately sped home and fired up the computer and the 2200. I
converted a color image to monochrome using the channel mixer
technique (staying in RGB) and printed the photo on Epson Premium
Semigloss paper--I know, I know, its not photo rag--and by golly, no
metamerism. And I mean NO metamerism. I then tried another one, but
this time after the channel mixer I switched over to the Duotone mode
and tinted the image, converted back to RGB, then printed. Again, no
metamerism and a beautiful warm tinted photo. Yes!
I don't like the way pigment based Ultrachrome inks affect the
surface sheen on resin paper. When the ink is laid down it takes on a
glossier sheen than the paper, making the image kind of look like a
decal when the light hits it just right. But I found a solution to
that. I sprayed the photo with two very light coats of Lumijet
ImageShield waiting a few minutes between coats. This acts as a
sealer for what is to follow, or you could just stop right there
since the ImageShield by itself gets rid of about 90 percent of the
sheen difference problem. I let that dry about an hour then
airbrushed on one wet coat of Hydrocote Satin thinned with distilled
water and amended with a bit of Hydrocote FloAyd. If anyone wants me
to go into detail on techniques for doing this let me know and I'll
make another post. The end result is a photo that looks exactly as
if it were printed with dye inks, that is, there is a consistant
sheen across the surface, and did I mention, NO metamerism. A bonus
here is that ImageShield contains a UV inhibitor so the photo should
be very longlasting. Gonna try the RGB thing on EEM next. Hope it
works, but I'm doubtful.
Re: Tidbits from Epson Print Academy
2003-01-07 by danielstaver <daniel@petraflux.com>
Are there any other settings you need to adjust to get this to work?
Because printing a BW image in RGB mode here on my 2100 produces an
image with a strong color cast and metamerism. I've tried almost all
possible combinations of printer-setting on BW images in RGB mode in
mye search for the best results, and so far all of them had color-cats
and metamerism.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sanfo2003
> and helpful folks.
RE: [Digital BW] Tidbits from Epson Print Academy
2003-01-07 by Ed Mathews
> From: sanfo2003 <SandyCornelius@...>
<snip>
> metamerism.
<snip>
Do you mean you printed this using all the Epson color inks (not just
black)?
Ed
http://lightandsilver.com
2003-01-08 by Jo Brunenberg
Hi Sandy,
Sounds great but I am not convinced....
Try the following:
Take a B&W stepwedge, Convert to RGB.
Print on Epson 2200 at 2880 dpi, Color.
Results will be: You will get all kind of color shifts along the stepwedge.
So the result will not be a neutral grey printed stepwedge which it should be.
Best regards,
Jo Brunenberg
http://www.jobrunenberg.com
and helpful folks.
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
2003-01-08 by sanfo2003 <SandyCornelius@cox.net>
---  "Jo Brunenberg" <jobnl@e...> wrote:
> ...Try the following:
stepwedge.
should be.
Hi Jo,
I tried what you suggested and yup, you're right, got some
unacceptable color shifts along the 21 step wedge on EEM paper, and I
thought that might happen with EEM as noted on my original post. But
tried the wedge on Epson resin paper (premium semigloss) and got a
nice neutral wedge that is virtually identical to the wedge I printed
using Pieziography selenium quadtones on my 1280 and no metamerism. I
say "virtually" because after carefully analyzing the wedge I picked
up an ever so slight magenta shift only at 35 percent black that is
so small its not noticable in a photo. I think it would be easy to
neutralize with maybe a one unit curve tweak, and one unit may be too
large. Even silver halide prints have a microscopic bit of color in
them -- they're not perfectly greyscale. Also, if a tint is added
that tiny shift at 35 percent becomes totally invisible. I guess
everyone has to draw their own line somewhere on what is acceptable
quality and then go out and take some pictures. Even Ansel Adams had
to say at some point, "Heck, that's good enough." But if I hear
comments like, "nice tinted print" when I didn't tint the print then
its time to move the line.
I'll leave it to someone smarter than me to explain why shifts occur
on EEM on not resin paper. I suppose it has something to do with
metamerism and the scattering of reflected light. I profiled both
papers identically using an EyeOne spectrophotometer and Gregtag
MacBeth ProfileMaker 4.0
Thanks for your reply.
-Sandy C.
My post only applied to Epson resin papers (premium semigloss and
luster). Printing on EEM or cotton papers seem to result in color
shifts across a greyscale wedge as you describe. However, I can get
Epson resin papers to print neutral across the wedge with no
metamerism, at least on my 2200.
First of all, printing B&W images in the RGB mode requires a spot-on
custom profile for your specific printer, paper, ink and dpi
combination; and your entire workflow should be color managed (color
managing my workflow also helps to keep me from going crazy).
Secondly, make sure you print in the Relative Colormetric rendering
intent if you're using Photoshop. Other than those two things the
setup is conventional.
Hope this helps. Take care
-Sandy C.
