Resolution Chart
2003-01-11 by Duncan Staples <gdstaples@yahoo.com>
Can someone post or direct me (WWW) to a resolution chart for printing? What I want to know is what image resolutions and DPI are best for each sized print, 4X6, 5X7, 8X10, 11X14 and so on. I know that there is a point in which everything else is overkill for a specific resolution and DPI. Thanks in advance, Duncan
2003-01-11 by Austin Franklin
> Can someone post or direct me (WWW) to a resolution chart for > printing? What I want to know is what image resolutions and DPI are > best for each sized print, 4X6, 5X7, 8X10, 11X14 and so on. I know > that there is a point in which everything else is overkill for a > specific resolution and DPI. Duncan, I don't know what you're asking. What printer are you talking about? What workflow? Typically, there is no "specific resolution and DPI" for printing B&W on an inkjet printer... The higher the resolution you send to the print driver, the better your output will be. This is true on the Piezo driver up to 720, and on the Epson driver to, I believe, 480? Print size makes no difference either. What I suggest is scan at optical resolution, and resize in PS but do NOT decimate the image, which you can prevent by not checking one of the boxes at the bottom of the resize window...it's obvious which one. The PPI will come out to some odd number, but just send that to the printer, and you should get the best results you can. Austin
Austin: I am talking about a Canon S9000 in both color and B&W and also best images for Fuji Frontier. Workflow is Photoshop direct from a Canon D60 or a scan from a 35mm transparency (Velvia or Provia) at 4000dpi with SS4000. Duncan --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Austin Franklin" <darkroom@i...> wrote: > > Can someone post or direct me (WWW) to a resolution chart for > > printing? What I want to know is what image resolutions and DPI are > > best for each sized print, 4X6, 5X7, 8X10, 11X14 and so on. I know > > that there is a point in which everything else is overkill for a > > specific resolution and DPI. > > Duncan, > > I don't know what you're asking. What printer are you talking about? What > workflow? > > Typically, there is no "specific resolution and DPI" for printing B&W on an > inkjet printer... The higher the resolution you send to the print driver, > the better your output will be. This is true on the Piezo driver up to 720, > and on the Epson driver to, I believe, 480? Print size makes no difference > either. > > What I suggest is scan at optical resolution, and resize in PS but do NOT > decimate the image, which you can prevent by not checking one of the boxes > at the bottom of the resize window...it's obvious which one. The PPI will > come out to some odd number, but just send that to the printer, and you
> should get the best results you can. > > Austin
2003-01-11 by shashinka@aol.com
In a message dated 1/11/03 1:57:50 AM, gdstaples@... writes: > Austin: > > I am talking about a Canon S9000 in both color and B&W and also best > images for Fuji Frontier. Workflow is Photoshop direct from a Canon > D60 or a scan from a 35mm transparency (Velvia or Provia) at 4000dpi > with SS4000. > > Hi Austin: At final print size, just have your file be from between 180ppi and 360ppi. 180 would be for larger prints and up to 360 for smaller prints. Digital C-prints do fine from about 200-300PPI at final size. All the best! Andrew Darlow ------ Photography, Digital Print Consulting and Custom Editions Andrew Darlow Images International, www.andrewdarlow.com Author: Inkjet Tip of the Month Club (newsletter) To subscribe, send e-mail to: Inkjettips-subscribe@yahoogroups.com [Non-text portions of this message have been removed]
> Austin: > > I am talking about a Canon S9000 in both color and B&W and also best > images for Fuji Frontier. Workflow is Photoshop direct from a Canon > D60 or a scan from a 35mm transparency (Velvia or Provia) at 4000dpi > with SS4000. > > Duncan Duncan, For a Fuji Frontier, there are different models, and the requirements are different. I'd suggest you speak with the operator and see what they recommend. I suggest scanning at full scanner optical resolution. Then when you downside, either D60 or scan use a stepped methodology, which has been described here and should be able to be found in the archives. It will retain detail that a straight downsize would not. Regards, Austin
2003-01-11 by Lyonscox
Duncan, I'm not really helping but maybe clarifying so some else can. Are we talking about the 'standard airforce resolution chart' like the one referenced here... http://www.displays.org.uk/DISNET/content/mtf.htm not that it's downloadable. Would be fun to have something like that in with the page like was set up for the exchange here... http://marktucker.com/exchange/ Just curious. Cleavis _______________________ Message: 4 Date: Sat, 11 Jan 2003 06:57:25 -0000
From: "Duncan Staples <gdstaples@...>" <gdstaples@...> Subject: Re: Resolution Chart Austin: I am talking about a Canon S9000 in both color and B&W and also best images for Fuji Frontier. Workflow is Photoshop direct from a Canon D60 or a scan from a 35mm transparency (Velvia or Provia) at 4000dpi with SS4000.
2003-01-11 by Roy Harrington <roy@harrington.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lyonscox" < lyonscox@c...> wrote: > Duncan, > > I'm not really helping but maybe clarifying so some else can. > > Are we talking about the 'standard airforce resolution chart' like the one > referenced here... > http://www.displays.org.uk/DISNET/content/mtf.htm > not that it's downloadable. Would be fun to have something like that in > with the page like was set up for the exchange here... > http://marktucker.com/exchange/ > > Just curious. > Cleavis > If that's what desired, this is a postscript description of the Air Force resolution chart. You can read it into Photoshop and rasterize it for any size and resolution you like. http://www.photo.net/learn/optics/USAF1951.ps Roy
No I am not talking about system or lens resolution I am talking about file sizes. What is considered the minimum file resolution and dpi to make a 5X7, 8X10 etc.... Thanks, Duncan --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lyonscox" <lyonscox@c...> wrote: > Duncan, > > I'm not really helping but maybe clarifying so some else can. > > Are we talking about the 'standard airforce resolution chart' like the one > referenced here... > http://www.displays.org.uk/DISNET/content/mtf.htm > not that it's downloadable. Would be fun to have something like that in
> with the page like was set up for the exchange here... > http://marktucker.com/exchange/ > > Just curious. > Cleavis > > _______________________ > > Message: 4 > Date: Sat, 11 Jan 2003 06:57:25 -0000 > From: "Duncan Staples <gdstaples@y...>" <gdstaples@y...> > Subject: Re: Resolution Chart > > Austin: > > I am talking about a Canon S9000 in both color and B&W and also best > images for Fuji Frontier. Workflow is Photoshop direct from a Canon > D60 or a scan from a 35mm transparency (Velvia or Provia) at 4000dpi > with SS4000.
