Re: [Digital BW] Re: partially clogged black print head...
2003-01-13 by John/Julie Gittins
Gary,
  The Epson OEM carts have always got the ink flowing again when I've used them
  for stubborn clogs. My success before being advised about their strong medicinal
  was not very good:  I replaced an 1160 printhead every 9 or 10 months for a couple
  of years. After replacing the bad cart with Eps OEM, I often get a perfect nozzle
  check after one cleaning cycle; and the tougher clogs have all yielded to the
  Eps OEM carts after letting them sit in the printer overnight.
  Whenever I do 3 cleaning cycles, I print a purge-pattern (downloaded from MIS's site).
  If the problem is only with the black, I edit out the color columns so I don't waste ink;
  if the problem is with the color cart, I remove the black column.
  Hope this helps.
  John
Re: Epson OEM black and MIS FS colors compatible?
2003-01-13 by Gary Benson <bensonga@gci.net>
> again when I've used them for stubborn clogs.
Thanks for the note John.  Since it is only my MIS FS black cartridge
and print head that is clogged, does anyone know if I can just
replace the MIS FS black with Epson OEM black and leave my half-full
MIS FS "color" cartridge (which is working perfectly) installed?  Any
problem with mixing the Epson OEM black and the MIS FS gray inks?  I
sure hope this clears up my black ink print head clogs.  I wasn't
looking forward to trying the Windex Direct Injection technique.
TIA,
Gary Benson
Eagle River, AK
2003-01-14 by chatzebussi <chatzebussi@yahoo.co.uk>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John/Julie
Gittins" <jgittins2@m...> wrote:
>   Gary,
>   Hope this helps.
>   John
John
How do you edit this purge-pattern, please?
Mathias
2003-01-14 by jim hayes <jimhayes@frii.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chatzebussi
> >   Gary,
column.
> >   Hope this helps.
> >   John
> John
> Mathias
Not needed, as MIS posts files for single color purge patterns
covering large area of letter-sized paper, ie, one for k one for cyan,
etc.
Jim H.
2003-01-14 by John/Julie Gittins
Jim,
Thanks for alerting us to the existence of separate-color purge files on the MIS site.
I hadn't looked at what they had available since downloading the 4- and 6-color
all-inclusive patterns in 2000.
John
  Sent: Monday, January 13, 2003 9:59 PM
  Subject: [Digital BW] Re: partially clogged black print head...
  > >   Gary,
  column.
  > >   Hope this helps.
  > >   John
  > John
  > Mathias
  etc.
  Jim H.
  - Good manners are required at all time. No personal attacks or &amp;amp;quot;flames.&amp;amp;quot;
Mathias,
I think Jim H's mentioning that both separate-color and full-cart-colors purge-patterns are
now available at www.inksupply.com (enter 'purging' in their search field) distracted
me from answering your actual question about editing the full-cart-colors pattern.
To edit, just open a purge-pattern file in an image-editor, select the part you want
and do a crop. You can shorten the columns of color as well as remove the colors that you
don't need to exercise. (I often use shortened columns, since printing the full column isn't
needed to repressurize after running three cleaning cycles).
John
  Sent: Monday, January 13, 2003 9:54 PM
  >   Gary,
  >   Hope this helps.
  >   John
  John
  Mathias
