MIS refill mystery
MIS refill mystery
2003-01-15 by sdsmith9999@aol.com
I'm getting a strange glitch with two MIS CMY carts for my 1160. When filling
the middle chamber with 75% original quad ink, only about half the ink goes
in before I can't add more, as if the chamber is full.
This happened on both a "de-foamed" cart and a virgin cart.
Using exact same methods and amount of ink the other two chambers fill w/o a
problem.
Any ideas?
Stephen Smith
Re: MIS refill mystery
2003-01-15 by Steven Karafyllakis <stevek@evcom.net>
Stephen,
Try starting form scratch again, do the vacuum draw as best you can,
and then take the chip of and microwave it. I give each side and
both ends a 3-4 second burst, and then draw out each chamber again
once or twice with the syringe. They always fill properly after
that. Don't let it get more than a little warm to the touch though,
you don't want that sponge melting!.
Steve K.
http://www.stevekphoto.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com,
When filling
ink goes
fill w/o a
> problem.
> Any ideas?
> Stephen Smith
