Somerset photo enhanced velvet paper
2003-01-09 by brigapig <jcwphoto@jcwphoto.com>
Are there any curves for Paul Roarks MIS variable inks 6 color on a 1280 for this paper. I thought I saw some but can't remember where. jcw
2003-01-09 by Murray Zaharia
I have a 1270 loaded with MediaStreet dye ink and a CFS. Nozzle checks are perfect and will print letter size perfectly. Soon as I try 13 x 19", I get some nozzles dropping out. Specifically, black and cyan. The nozzle check will sometimes show some black ink lines mixed in with the cyan line position when this happens. (cartridge problem?) I have already wrecked 5 13x19's this way. Soon as it happens, I run a nozzle check and usually one cleaning cycle will do it for a perfect nozzle check. I can then print letter size with no problem, but then 13x19" turns up the problem again. I tried raising the bottles a little, but this gave me another problem of ink blotches, so I put them back down. I am beginning to think that the CFS is to blame and for some reason can't keep up the inkflow with the larger papers being printed. Anyone have something similar happen? Murray Z.
2003-01-09 by Charles Bandes <byronbulb@yahoo.com>
This has happened to me on my 2000p with CIS - only when printing on rolls of paper. (And then only two-thirds of the way through a 13x44 - DOH) Sure is frustrating!! I have no solution. :( --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Murray Zaharia" <zaharia@t...> wrote:
> I have a 1270 loaded with MediaStreet dye ink and a CFS. Nozzle checks > are perfect and will print letter size perfectly. Soon as I try 13 x > 19", I get some nozzles dropping out. Specifically, black and cyan. The > nozzle check will sometimes show some black ink lines mixed in with the > cyan line position when this happens. (cartridge problem?) I have > already wrecked 5 13x19's this way. Soon as it happens, I run a nozzle > check and usually one cleaning cycle will do it for a perfect nozzle > check. I can then print letter size with no problem, but then 13x19" > turns up the problem again. I tried raising the bottles a little, but > this gave me another problem of ink blotches, so I put them back down. I > am beginning to think that the CFS is to blame and for some reason can't > keep up the inkflow with the larger papers being printed. Anyone have > something similar happen? > > Murray Z.
2003-01-10 by Peter McLennan
At 01:49 AM 1/9/2003, you wrote: >I have a 1270 loaded with MediaStreet dye ink and a CFS. Nozzle checks >are perfect and will print letter size perfectly. Soon as I try 13 x >19", I get some nozzles dropping out. Specifically, black and cyan. The >nozzle check will sometimes show some black ink lines mixed in with the >cyan line position when this happens. (cartridge problem?) I have >already wrecked 5 13x19's this way. Soon as it happens, I run a nozzle >check and usually one cleaning cycle will do it for a perfect nozzle >check. I can then print letter size with no problem, but then 13x19" >turns up the problem again. I tried raising the bottles a little, but >this gave me another problem of ink blotches, so I put them back down. I >am beginning to think that the CFS is to blame and for some reason can't >keep up the inkflow with the larger papers being printed. Anyone have >something similar happen? > >Murray Z. How old is your CIS? If it's more than a year or so, you may have a clogged cart(s). I had problems similar to this and replacing the CIS carts solved it. It seems that the lines and/or the carts can get clogged due to evaporation of the black vehicle from the ink. Nozzle checks can be fine, since they have very low ink demand, but printing a 13X19 is a much higher demand on ink flow than printing test or a letter size image. To test for ink starvation, print a solid black sheet (letter size will do) at *high speed*. If it begins to show white lines halfway through the sheet, you've found your problem. hope this helps, Peter
2003-01-15 by Murray Zaharia
From: Murray Zaharia [mailto:zaharia@...] Sent: Thursday, January 09, 2003 12:49 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Has anyone seen this before? I have a 1270 loaded with MediaStreet dye ink and a CFS. Nozzle checks are perfect and will print letter size perfectly. Soon as I try 13 x 19", I get some nozzles dropping out. Specifically, black and cyan. The nozzle check will sometimes show some black ink lines mixed in with the cyan line position when this happens. (cartridge problem?) I have already wrecked 5 13x19's this way. Soon as it happens, I run a nozzle check and usually one cleaning cycle will do it for a perfect nozzle check. I can then print letter size with no problem, but then 13x19" turns up the problem again. I tried raising the bottles a little, but this gave me another problem of ink blotches, so I put them back down. I am beginning to think that the CFS is to blame and for some reason can't keep up the inkflow with the larger papers being printed. Anyone have something similar happen? Murray Z. Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - Include your full name with your message. - Include the address of your website, if you have one. - As threads develop, trim off excess portions of earlier messages to keep them short. - As the topic of a thread changes remember to change the subject header. - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; - Complete your Yahoo profile. - Before posting a question, search the message archives and the various resources on the homepage. Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ I have a new set of unused MIS VM HEX inks for sale. Six bottles of four ounces each for a 6 color printer. I have decided to use the VMS inks instead. I will sell the inks for $60.00. (postal shipping included) First to respond off-list, gets them. If interested, please respond - email me only OFFLIST at: zaharia@... Murray Z.
Sorry. Don't know what happened with the first post. Something strange happening at Yahoo. Anyway, I have a new set of unused MIS VM HEX inks for sale. Six bottles of four ounces each for a 6 color printer. I have decided to use the VMS inks instead. I will sell the inks for $60.00. (postal shipping included) First to respond off-list, gets them. If interested, please respond - email me only OFFLIST at: zaharia@... Murray Z.
