is THIS microbanding
2003-01-16 by franklinmiller4 <proxy@photocommando.com>
Hi -
 Just started using MIS inks with a Niagara CFS in an Epson
1270 and am noticing teeny-weeny white lines running through
the print, parallel to the movement of the print-head.
 Is this microbanding? I'd been under the impression that
microbanding was BLACK lines...
 Whenever I run test patterns the lines are all OK.So would
popping on an OEM cartridge set for while be of any use?
 Thanks!
f
Re: is THIS microbanding
2003-01-17 by Gregory Schern <gschern@yahoo.com>
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "franklinmiller4
<proxy@p...>" <proxy@p...> wrote:
> Hi -
>  Thanks!
> f
frank,
check out this page on our site in the faq/info base section. it has
several examples of microbanding to varying degrees and an
explanation.
http://www.inkjetgoodies.com/faq_printing.htm#faqp1
good luck.
Gregory Schern
InkjetGoodies.com
info@...
1 866 330-4514
2003-01-17 by jim hayes <jimhayes@frii.com>
I'd like to add one small trick to what Gregory has posted below.
Indeed it could be misfiring nozzles and I guess you might want to
eliminate the possiblities there first.
On the Epson 3000, people had problem with banding caused by paper
transport (Gregory mentions this). If the lines were dark the paper
wouldn't be advancing enough and white banding indicated too much
travel. So the trick that folks did was to print out a file of known
size- say 9.75 inches or whatever...then measure the print afterward.
If the print was more than 1/16 inch longer then often it correlated
with white banding (print was traveling too far). If print was shy of
file dimension within a 1/16, dark banding would occur. Then either a
re-alignment can be done for paper thickness, or occasionally...back
to Epson tech. Probably not as likely these days with improved
transport such as the 1270 has, but worth a quick check.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gregory Schern
<gschern@y...>" <gschern@y...> wrote:
> --- In
> > Hi -
> >  Thanks!
> > f
> frank,
> explanation.
> good luck.
> Gregory Schern
> InkjetGoodies.com
> info@i...
> 1 866 330-4514
