Prints turn to vertical lines
2003-01-21 by Steven Karafyllakis <stevek@evcom.net>
Hello all;
I seem to have a bit of weirdness going on: occasionally my 1280
decides about 1/4 of the way down a print that all image data is
straight lines, and procceeds to print everything in vertical lines
down the rest of the image, with the tone of each line coresponding
to the tone it was printing when it decided to flip out. The effect
is quite Dali-esque, it looks like the image just ran sown the page,
but in a very organized fashion. Turning off the printer gets me a
few good prints, until it happens again. Only happens on vertical
prints 4x6-ish and up in size. Any ideas?
 Also, a Photoshop glitch: when I try to save a TIFF I get a message
that "Cannot save *******.tif because the file is in use or was left
open"  Come again? why else would you want to save a file anyway?
Has anybody else haad the problem? I thought it was only PS 7 but
this morning PS 6 did it too. Help!
Thanks for any ideas;
Steve Karafyllakis
Re: Prints turn to vertical lines
2003-01-21 by dsmithhfx <dsmithhfx@yahoo.com>
There could be anumber of possible reasons, but without knowing more
about your particular setup I would look at a memory/spooling error
to start with. Try turning off spooling/background printing. Also,
try printing at different image sizes and resolutions to see if the
problem is aggravated by larger file sizes.
Photoshop problem -- I've had that occur periodically, usually a
reboot clears it up. Try saving the file to a different location.
Also see if your scratch disk(s) are all filled up, if so try
Edit/Purge/All (losing any possibility of undo/history).
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dsmithhfx
more
error
Thanks for the feedback; I've been mulling it over all day (the
printing problem) and I've come to the conclusion that it's likely a
spooling problem as well, so I'll set it to print directly to the
printer and see if that helps.
As for th PS file-saving problem, I have a 5.6G scratch disk in a
seperate partition, I'm inclined to look elswhere. Odd thing is that
if I save a PS file as a tiff it works fine, but I can reopen that
very same tif, edit it, and then can't save it. Weird.
Thanks again, Steve K
2003-01-22 by Steven Karafyllakis <stevek@evcom.net>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
> more
> error
Also,
> the
location.
a
that
An update- I've never turned of the spooling before-it seems ti fix
the problem, but Quark Xpress, out of which I'm printing this,
freezes until the print job is done. It didn't register before, but
this only happens when printing out of Quark 4.0. So... the rule of
thumb is, 'the more expensive the software the buggier it is'???
Steve K
2003-01-22 by dsmithhfx <dsmithhfx@yahoo.com>
> Steve K
Well if you turn off spooling, your pc is 100% dedicated to the print
job, instead of running it in the background. If you have another pc,
you could use that as a print server.
2003-01-23 by Steven Karafyllakis <stevek@evcom.net>
fix
but
of
> > Steve K
print
pc,
Right! I do in fact have an older machine I had intended to use as a
server, but I loaned to a friend in need... I guess I'll have to put
up with it, I don't have to use Quark that often anyway. besides, I
seem to have given myself bigger and badder headaches with this 7500
I picked up last week, as you'll see from my other post.
Thanks for the help.
Steve K
