Re: Quark printing problems (WAS: Prints turn to vertical lines)
2003-01-23 by Doug I.
Steve,
Not sure of the original question, but I just finished resolving some
bizarro Quark problems when printing high-res tiffs (Mac OS 9.2 in my case,
but many of these issues are cross-platform).
First off, definitely upgrade to 4.11 (free on Quark's site).
The other info I found was that rotating a photo file in Quark will cause
low-res printing. Do any rotating in Photoshop, then import the rotated file
into Quark.
Finally, if the picture box color is set to "none" (which you would think
would be logical), this can also cause freaky or low-res pic printouts. It
must be set to "white". Go figure.
Their FAQ is helpful, although answers can be spread over several sections,
so be sure to read the entire index:
 http://www.quark.com/support/techinfo/
HTH,
Doug
> Date: Thu, 23 Jan 2003 04:10:58 -0000
> From: "Steven Karafyllakis <stevek@...>" <stevek@...>
> Subject: Re: Prints turn to vertical lines
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dsmithhfx
> <dsmithhfx@y...>" <dsmithhfx@y...> wrote:
>> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
>> Karafyllakis <stevek@e...>" <stevek@e...> wrote:
>>> An update- I've never turned of the spooling before-it seems ti
> fix
>>> the problem, but Quark Xpress, out of which I'm printing this,
>>> freezes until the print job is done. It didn't register before,
> but
>>> this only happens when printing out of Quark 4.0. So... the rule
> of
>>> thumb is, 'the more expensive the software the buggier it is'???
>>> Steve K
>> Well if you turn off spooling, your pc is 100% dedicated to the
> print
>> job, instead of running it in the background. If you have another
> pc,
>> you could use that as a print server.
> Right! I do in fact have an older machine I had intended to use as a
> server, but I loaned to a friend in need... I guess I'll have to put
> up with it, I don't have to use Quark that often anyway. besides, I
> seem to have given myself bigger and badder headaches with this 7500
> I picked up last week, as you'll see from my other post.
> Thanks for the help.
> Steve K
