[DigitalBW] Re: Help with MIS orig quadtone inkset
2003-01-30 by lsolszewski <lsolszewski@yahoo.com>
Thank you. I will look up the Brandin workflow. I neglected to inform
that I am using an Epson 3000 printer. Thanks again, -Lou.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John/Julie
Gittins" <jgittins2@m...> wrote:
> On 1/29/03  9:16 PM, "Lou <elgha2001@y...>" wrote:
> > I decided to try digi bw printing. My friend suggested MIS
> > inks. I called and was directed to the original formula, which
does
> > not seem to work with Paul's curves (I was impressed with his
> > prints). Can anyone suggest a workflow for this combination of
ink
> > and printer?
> I used MIS original quads until late last spring (w/ 1160 and 740).
> These inks have a warm tone which increases some for a while
> as a print ages. I used Chris Brandin's (partitioned) workflow.
> I was pretty satisfied with it (used it from the time it was first
> posted on the MIS site, about Dec. 2000). His workflow was
> developed specifically for the original quads, and he provides
> clear instructions, as well as curves for a number of different
papers.
> I shifted to the Randall and the Woolf workflows, which are keyed
> to the MIS's "Full Spectrum" inkset, because I wanted a more
neutral
> tone and a darker black.  At present, though, I don't see my
Brandin
> workflow prints as obviously inferior to prints from the other
> two. So I'd suggest using it with your MIS original quads.
> One caution to mention if you're using cartridges: I discovered
> that the positioning of the 3 tones in the grays cartridge differs
> depending on whether it's an "original" or a "full spectrum". So
> the Brandin workflow doesn't work with FS inks, and the Randall
> and Woolf workflows won't work with MIS's standard positioning
> of the grays in the original inkset cartridge.
> John
does
ink
> > and printer?
papers.
neutral
Brandin
> John
2003-01-30 by John/Julie Gittins
> inks. I called and was directed to the original formula, which does
> prints). Can anyone suggest a workflow for this combination of ink
> and printer?
clear instructions, as well as curves for a number of different papers.
to the MIS's "Full Spectrum" inkset, because I wanted a more neutral
tone and a darker black.  At present, though, I don't see my Brandin
John
