[Digital BW] Re: Epson 7500 what inks should I use?
2003-02-07 by Paul Roark
I just loaded my first attempt at a B&W inkset for my 7500 last night.  It's
not final yet, but I'm working on the issue.  The vm curves are done only
for the 7000 and PC.  I'm working on a new approach.  Here are a few of my
thoughts.
S\ufffdren Lindqvist wrote:
> With an 7500 dedicated for BW inkset, what kind of
>inkset should I use?
Steve K. wrote:
>The question you need to answer before deciding on inks,
>is how are you going to control them? ...
>Option 1) The specialized software almost certainly gives
>the best results, but particularly at this size, is
>very expensive. ...
I hope to have an inkset that will allow a RIP to do a good job, but I also
want the inkset to be controllable by the Epson driver.  That puts some
price pressure on the RIP sellers.  There will (hopefully soon) be some new
RIPs that might be much cheaper than the existing ones.
>The partitioned workflow approach: When it works well,
>it works very well also, ...
I don't know if the 7000 vm curves work on the 7500.  I'm not interested in
the old vm.  The new vm may be a few weeks off.  I'm more interested in a
new version of the vm-s, with a range from slightly cool/selenium to sepia.
>I have been using a ... Epson Archival Black ...
> for the gray positions, and the new Cone Museum K for black.
That is what is in my 7500 now.  The MIS matte black/PT Museum K in the K
position, Epson Archival Black in the cyan position, then dilutions of gray
and a toner.  The goal is a variable-tone, dual-K machine that can print on
matte or RC papers with software black ink switching.  But, my inkset is not
ready to go yet.  I've been able to do software switching on a quad, so I
think the Epson driver might be able to do it on the 7500.  It's going to be
a few weeks before I have it all sorted out.  I'll, of course, publish any
curves I make that control whatever inkset I end up using.
>...I need better ... dithering ...
I also have a few unacceptably rough spots on my 7500.  The 7000 with the vm
inkset and curves was able to get a smooth output.  So, I think the driver
should be capable of it.  Getting the right combination of settings and
curves might be able to smooth it out.
>There is one other possibility cropping up, that is in the
>development phase: something called Gimp-print, which is a Linux-
>Unix-Mac OS X printing utility. ...
I hope this pans out, but I don't think it's quite ready for prime time and
PCs yet.
http://www.PaulRoark.com
Steve,
>...I too am just now setting up a 7500 for B&W fine art printing
>The partitioned workflow approach: When it works well, it works very
>well also, but as far as I know,  there is only a set of curves
>available for the MIS VM inks and the 7000,
If I don't get a solution soon to the problems I've run into with the new
inkset, I'll just make an improved version of the existing vm-s inkset and
write curves for the 7500.  Since the vm in the 7000 works, I'm quite sure
we'll at least have some viable Epson-driver inkset to fall back on.
>... for the 7500, and am ... using Epson Archival Black
>(drawn out of a 7500 cartridge and diluted with clear Epson
>base stock) for the gray positions,
What clear base are you using?  My initial experiments with the MIS clear
base looked fine, but they did not do well in a fade test.  I don't know
whether it is the MIS clear base or whether the Epson Archival black just
does not perform well diluted.
My impression of Epson Archival Matte K is that it is great as a black for
RC paper -- the highest pigment dmax I've seen.  It is also solid on EEM at
the 100% spot in terms of fade resistance.  At the 50% patch it is not quite
as good, dropping 0.02 units versus 0.00 for Epson and MIS Photo Ks.
Why didn't Epson use the Archival black in the UC inkset?
Why does new Epson UC Photo K not have quite as high a dmax?
I hate to even mention the possibility, but does Epson Archival K have some
dye in it?  The diluted performance is similar to what I see with MIS FS/VM
K.  This just does not make sense.
I will soon test new 1000 Arc K diluted with MIS's new UC base to see if
there are any differences.  However, for now, I do not recommend Epson 7500
k in any diluted solution.
I think we really need to find a cooperative company with a high-end fade
tester that can hold the humidity up to where it should be.  My tests just
do not show any beneficial effect from the Epson coatings.  The last test I
did was even on a water bath to try to raise the humidity -- no effect.
I think paint and coatings companies, among others, have these machines.  If
anyone has any contacts with such companies, perhaps we could get a little
free test time.
I also think Cone and Zeiss should hire RIT to compare their new matte
blacks to Epson's Archival black.  If RIT tests show the same results I get,
advertising that the new matte black beats the black Epson uses in its "200
year" "Archival" inkset might be real impressive.  (The Epson representation
is still out there on non-U.S. Epson websites.)
If the Epson coating is mostly hype, we need to know it.  The new base that
has been developed allows third party RC compatibility with no coating on
the particles.  My tests indicate these are excellent inks for our uses.  I
have no interest in paying Epson's prices if the coatings do not add to
longevity.
2003-02-07 by Steven Karafyllakis <stevek@evcom.net>
<paul.roark@v...> wrote:
> Steve,
very
the new
inkset and
quite sure
on.
A 7500 version of the VMS inkset sounds good as a fallback, though
the double-K idea sounds even better. I do hope you can overcome
whatever control problems have presented themselves.
MIS clear
don't know
black just
That's not good news... I am using the MIS clear base. So you
suspect the base is more to blame? Should I assume that if I dilute
the Cone Museum K it too will do no better? What other choices are
there for mixing your own, is the new base available anywhere?
BTW the overly dense blacks I reported when I first tested the 7500
went away when I got rid of the GEN 4 K. Head slant alignment got
rid of some of the grittiness, and between that and your suggestion
to try the Watercolor setting, I'm getting some pretty reasonable
results-which makes this ink problem all the more vexing.
Steve K
Re: [Digital BW] Re: Epson 7500 what inks should I use?
2003-02-07 by Jerry Olson
Paul, I don't think I've ever asked about this, but are there any DYE
based quad inks with a super dense, deep black that are supposedly
archival, and would last at least 25 years under low light conditions?
Right now, I'd be pretty happy with a DEEP black that lasted 25 years or
so. And I don't suppose the dye inks would have any flaking problems.
Jerry
2003-02-08 by Roy Harrington <roy@harrington.com>
night.  It's
done only
are a few of my
> thoughts.
> >very expensive. ...
but I also
puts some
be some new
interested in
interested in a
black.
Museum K in the K
dilutions of gray
can print on
inkset is not
quad, so I
going to be
publish any
Linux-
time and
> PCs yet.
> Paul
Hi Paul,
I'm also interested in your new ink ideas for the 7500.  I
don't have one yet but I'm getting there.  Currently I just
run vm-sepia inks on an 1160.   I'm the one who
started this recent gimp-print flurry.  I've got the OS X
version working fine.  It eliminates the whole GCR issue
which makes the curve design much easier.  I don't know
if this option is open to you but with some Linux effort
this whole thing could be open to PC machines as well.
Roy
RE: [Digital BW] Re: Epson 7500 what inks should I use?
2003-02-08 by Paul Roark
Roy,
If there is a free (or even fairly cheap) RIP that works on PC and does a
good job on the 7500, I'm all ears.  That's exactly what I want.
I have not followed the Gimp-print thread enough to know if that approach is
viable yet on a PC for a non-programmer.  Once it is and someone can explain
it to me well enough to get running, I would move in that direction.
________________________________________
  Sent: Friday, February 07, 2003 4:05 PM
  Subject: [Digital BW] Re: Epson 7500 what inks should I use?
  night.  It's
  done only
  are a few of my
  > thoughts.
  > >very expensive. ...
  but I also
  puts some
  be some new
  interested in
  interested in a
  black.
  Museum K in the K
  dilutions of gray
  can print on
  inkset is not
  quad, so I
  going to be
  publish any
  Linux-
  time and
  > PCs yet.
  > Paul
  Hi Paul,
  Roy
page.
them short.
  - Good manners are required at all time. No personal attacks or
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
2003-02-08 by Steven Karafyllakis <stevek@evcom.net>
> Roy,
does a
approach is
can explain
direction.
> Paul
Yeah me too! I just spent most of last night and half of today
installing and trying to understand Linux, but I can see that I have
a lot to learn to implement your gimp-print solution. So if any of
the folks working on it in Linux would translate it to English at
some future date, it would be very much appreciated!
Steve K
>   -----Original Message-----
>   From: Roy Harrington <roy@h...> [mailto:roy@h...]
>   night.  It's
>   done only
>   are a few of my
>   > thoughts.
>   > >very expensive. ...
job,
>   but I also
>   puts some
>   be some new
>   interested in
>   interested in a
>   black.
>   Museum K in the K
>   dilutions of gray
>   can print on
>   inkset is not
>   quad, so I
It's
>   going to be
>   publish any
>   Linux-
prime
>   time and
>   > PCs yet.
>   > Paul
>   Hi Paul,
>   Roy
Polls and
wish to
this same
> page.
messages to keep
> them short.
subject header.
various
Service.
2003-02-09 by Paul Roark
I've been playing with the 7500 again today and have a few observations that
might be useful.
First, I unchecked the "High Speed" box in the driver.  It substantially
smoothed out some roughness I had.
Second, the Watercolor paper setting is giving me a 1.69 dmax with EEM and
MIS high-load matte black (like Museum black).  (By the way, I have a Museum
black 220 universal cart I'll sell for below cost.)  The second best dmax
appears to be with the Photo Glossy paper setting -- 1.65.
Third, I have persistent micro-banding with radical partitioning curves.  It
did not show up with the OEM inks, and it appears to be less with more mild
curves.
Does anyone know if the shaking of the Epson stand has any effect on the
print quality?
I will probably load the new MIS UC-clone-based vm into the machine in a
week or so.  The original vm worked well in 7000 and 9000 printers, so I
assume it'll be fine in the 7500 -- we'll see.  The MIS UC-clone inks are
excellent for midtones.  The warm end is not quite sepia, but better than
the old vm inkset, and it'll still go plenty cold.
In the meantime, I'm seeing whether the dual-k vms will work if I
re-formulate it to get rid of the weak diluted Epson Arc black.
2003-02-09 by Steven Karafyllakis <stevek@evcom.net>
Hi Paul;
A couple things to add about the 7500-
I got rid of another small but noticeable increment of graininess by
doing a very carefull 'B-head slant' alignment, that got me back to
round dots instead of oval.
The other thing I've discovered, is that feeding a large file to the
Epson driver for a small print results in some rather fuzzy
downsampling. That surprised me, since I saw no sign of that with
the 1280 driver. It works much better to resize AND downsample in
PS, with a final light sharpening than to send it directly to the
printer. What works even better in terms of sharpness at least, is
to print it through Qimage - the downsampling and 'smart sharpening'
they use is extraordinary. It is also CM compliant, though I don't
know it well enough to tell you if you can use partitioning curves
with out apllyihg and saving in PS first. Probably not worth the
nuisance.
observations that
> might be useful.
substantially
EEM and
have a Museum
best dmax
curves.  It
more mild
> curves.
on the
> print quality?
$500.00 for the damn thing and it shakes uh?! Merde! I can't help
there, I couldn't afford the stand so it's on my counter.
machine in a
printers, so I
inks are
better than
Can you get base liquid for the UC-clones? That's what I need most
right now.
Steve
> Paul
2003-02-10 by Ernst Dinkla
To: "DigitalB&WPrint" <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Sunday, February 09, 2003 11:19 PM
that
> might be useful.
There is a quality increase in the slow setting, however a good head
adjustment for the new inks will increase the quality in all settings.
With Generations and good head adjustment I see small quality differences
between slow and bidirectional. The service manuals are available through
the 9000 (now "EpsonWideFormat") list and archives.
It
mild
> curves.
> print quality?
It doesn't. The shaking will also keep your pigments suspended :-)
With the the 9500 and Generations inks most users got better results with
the 9000 driver. The Generations inks were mixed for the 9000 dye
generation. The 9500 higher voltage to the nozzles may be an advantage for
the UC clones as their rheology probably is different, could be that the
9000 driver isn't then the best choice either.
Ernst
2003-02-10 by Paul Roark
Ernst,
Thanks for responding.
>>... I unchecked the "High Speed" box in the driver.
>>It substantially smoothed out some roughness I had.
>... The service manuals are available through
I've done the usual alignment that is accessible via the driver.  I've also
checked the B & C Head Slant/Height adjustments through the 7500's display
panel.
Are there any other adjustments that would affect microbanding?
> With the 9500 and Generations inks most users got
>better results with the 9000 driver. The Generations inks
>were mixed for the 9000 dye generation. The 9500 higher voltage
>be that the 9000 driver isn't then the best choice either.
Is there more to "rheology" than viscosity?  (I'm not a chemist.)
One of my theories in purchasing a 7500 was that, being made for pigments,
it might be better for the pigmented inks I use than the 7000.  For example,
it has been my impression that the new "high-load" pigmented inks are close
to the limit that standard desktop printers can handle.  Also, I think, that
the pigmented printers might have some firmware (?) routines for cleaning
that may be useful.
When doing curves for the 7000 and 9000, what I noticed with them is that
the Epson driver gave a lower dmax than the desktop printers.  The 7500, on
the other hand, is said to pump out a lot of ink.  That may also be the
voltage difference you mentioned.  The dmax I'm getting with the
"Watercolor" paper setting is higher than my 1160.  So, it looks like the
7500 does have a better dmax than the 7000 with the Epson driver.
If I do try the 7000 driver, is that anything more to it than just
downloading/installing it?
also
> panel.
Then you are already in service mode for adjusting the heads manually
(screwdriver included). So you have covered all adjustments. It is however
important to do it with the inkset + paper that will be used in printing
later on.
It belongs in the physics department I guess. Viscosity, tixothropy, surface
tension, capillary action, electrostatic load etc. Not only on flow in the
ink channels but how it will act in the piezo pump chamber, droplet
formation, impact on the coating, adherence to the coating, flow in the
coating's absorbers. High speed camera shots of droplet formation at the
nozzle exit, that kind of stuff.
example,
close
that
> that may be useful.
There's an additional heavier cleaning in the 9500 firmware compared to the
9000. On the US Epson site there's a firmware upgrade for that purpose.
on
For some time I'm thinking that there is one advantage in the older pro
printers. If you need the heaviest ink load it is unlikely that you get that
with the latest models that combine higher speed with finer droplets and
higher resolution. The density can be increased with higher pigment loads
per ml but there will be a brick wall where the ink viscosity needed for
higher pigment load suspension is too low for the maximum piezo pump
activity possible (at high speed and resolution). To keep the high pigment
load suspended while the ink is static and still get flow at the pumping
action is the trick. Increasing tixothropy is then the way to go, it also
gives a better setting of the ink at the coating so less bleed. Not so nice
for gloss printing though as the ink sets before it gets into the coating.
Glyzerine is most likely the stuff used in the highload pigment inkjet inks.
In offset and silkscreen printing the finer the screen resolution the
thinner the inklayer has to be otherwise dotgain gets out of hand. That
limits the maximum density as well. Making the ink more tixothrophic and
giving it a higher pigmentation will end in less gloss and problems with the
water balance in offset printing. Inkjet printing has more similarity with
(roto)gravure printing (the diazo dyes for example) but part of those rules
will still hold if it was just the detail contrast maximum. That was
gravure's achilles heel.
The 9600/7600/10600/2200 have the advantage of the grey ink of course. Where
3 inks were needed to get a grey with a certain density  there's only one
grey ink needed that probably has a slightly higher density than the darkest
of the CMY inks. Not only does it control the neutrality better it also
reduces the inkload and so less bleed (dotgain) at the same density.
For the 9500 it is just like that. I guess it will be the same for the 7500.
Diana York uses the 9000 driver for her 9500 that was (is) loaded with
Generations.
Ernst
2003-02-16 by Paul Roark
I have my latest version of the VM inkset running on the 7500.  UC VM 4.3
(my terminology) is 100% MIS UC clone inks.  By sticking with a
carefully-engineered inkset, the banding of my last experimental effort is
gone; there are no signs of any incompatibilities.
I've been using the 7000 driver with the 7500.  The curves needed to control
the inks appear to be smoother, resulting in very few artifacts and smoother
ramps that I was getting with the native driver.  The printer monitor (ink
levels, etc.) doesn't work, but the driver prints fine anyway.
The output is not as smooth as a modern desktop hextone printer. On very
close inspection I can see some dots or slightly rough dither.  In small
prints, this might be objectionable.  For display prints it's probably
irrelevant.
I'm not sure why the 7500 with the 7000 driver is producing slightly more
prominent dots than the 7000 and 9000 do with the MIS VM inkset.  Factors
could include the 100% pigment (no dye) composition of the UC VM 4.3 inkset.
I suspect the small amount of dye that appears to be in the older inkset
could have softened the edges of those dots.  Also, the VM 4.3 base gray ink
(mostly MIS 7600 Light Black) is warmer.  As such, the color contrast
between the toner and the base gray ink is greater.  Finally, it could be
that the 7500 uses an increased head voltage that pumps out more ink per
dot, making each dot darker.
If the last factor is the source, for display prints I'd opt for the 7500
due to its better blacks, even if it is a bit rougher than the 7000.  I'm
getting 1.68 on new EEM with MIS 7600 matte black (like Museum black) versus
1.59 for the 9000 MIS VM-k on old EAM.  (This would be even lower with new
EEM.)  The 7000 and 9000s I wrote curves for always had weaker blacks than
the desktop units.  This 7500, however, is right up there with the 3000 in
terms of good blacks.
I might add that UC VM 4.3 is balanced to give a print that matches the
lightly-selenium-toned silver print with the "nc" curve.  It's virtually
identical to the PiezoTone Selenium.  On the warm side, it's twice as warm
as the old MIS VM.  The tone matches the albumen prints (good reproductions
I was able to buy from the Getty) of Gustave Le Gray, although the
saturation of the UC VM 4.3 warm is half that of the old albumen prints.  It
cannot reach to full sepia warmth.
So, for display prints, I think this combination -- 7500 & UC VM 4.3 --
makes a good match.  For small prints, keep your modern desktop hextone
printer.
I assume MIS will mix the UC VM 4.3, but that is their decision.  I'm not
sure what name they will assign to it.
2003-02-17 by Steven Karafyllakis <stevek@evcom.net>
VM 4.3
effort is
to control
and smoother
monitor (ink
On very
small
probably
> irrelevant.
slightly more
Factors
4.3 inkset.
inkset
base gray ink
contrast
could be
ink per
the 7500
7000.  I'm
black) versus
with new
blacks than
3000 in
matches the
virtually
as warm
reproductions
prints.  It
4.3 --
hextone
> printer.
I'm not
> Paul
Hi Paul;
VM 4.3
> (my terminology) is 100% MIS UC clone inks. >
Quick work! I hope MIS is just as quick to produce, I can think of a
couple people awaiting anxiously....
slightly more
Factors
4.3 inkset.
inkset
When I first ran my 7500 I had GEN 4 K in it, and it seemed that
made the problem worse, at least for me. Of course that ink probably
has a lot more dye in it that the "all pigment" blacks???
ink per
This one gets my vote, I think the machine is just set up to spit
out more black ink to make up for the whimpy D-max of the Arc-K.
I would be curious to compare dot-size & graininess, would you
consider exchanging a print / grayscale?
Also: For those who where curious I have an amusing horror story to
report on my efforts to install and learn Linux so I could try Gimp-
print. The short version is; I installed SuSE which seemed to have
the lates version of everything, couldn't even get my printers to
work. Formatted the drive, installed Red Hat, could get my printers
to work. Went back to Suse, still no go. And all this time, mind
you, damn near nothing else worked either: no modem. no audio,
rudimentary scanning, Suse wouldn't drive my monitor properly, in
short, a mess. And then the fun began: I decided to scothch the
whole thing, but discovered that I couldn't get rid of the Linux
bootloader. Before I figured out how, I tried 3 'repair
installations' of Win XP, and the only thing that got 'repaired' was
my internet connection, I no longer have one, and don't have the
option of setting up a new one. I am now online through a second
installation of Win XP on the drive that I had Linux. Bah-humbug!
One note however; for anyone using Linux already, who maybe hasn't
updated recenlty: The Gimp-print driver that Roy is using is 4.3.4;
That's still very developmental; the one before that 4.3.3, is
included in SuSE and other places, and already supports quadtone B&W
printing. The release notes state that it hasn't been tweaked for
any particular ink/paper sets, so it would still require some fine-
tuning, but it might be worth checking out for those inclined to
experiment
Steve K
2003-02-17 by Paul Roark
Steve,
>>UC VM 4.3 (my terminology) is 100% MIS UC clone inks. >
>Quick work!
I'm desperate.  I have a show to print for, so this beast has to produce.
MIS seems to respond to polite harassment.  I think MIS is fairly
comfortable with the formula, since it uses inks the are MIS inks and have
been thoroughly tested.
>>is producing slightly more prominent dots than the 7000
>>... it could be that the 7500 uses an increased head voltage
>>that pumps out more ink per dot, making each dot darker.
If this is what it takes to get better blacks from the pigments, then I
think I agree with Epson's decision to sacrifice a little smoothness for the
sake of a good black.  In display prints only those looking for the dots
with their noses in the prints will have any chance of seeing any.  I bought
a pair of the strongest reading glasses the local drugstore sells so that I
could duplicate those with nearsightedness (or youth) who stick their noses
into the prints.  At normal viewing distance (Kodak uses 14" to measure
grain) there is no problem.
Sure.  Maybe we can see if all the 7500s are the same or one of us bought a
turkey.  (On the other hand, maybe ignorance is bliss.)
You might also be interested in seeing the UC VM 4.3 inkset.  I have the
neutral curve essentially final, and the warm curve is tonight's project --
and close to done.  The inkset can go cold also, but I don't have much
interest in going very far in that direction.  I'll make other curves
eventually, but the warm and neutral are the most important for me.  Contact
me off list about the exchange.
2003-02-17 by Roy Harrington <roy@harrington.com>
hasn't
4.3.4;
quadtone B&W
fine-
> experiment
> Steve K
Steve,
Assuming I'm the Roy you are referring to  --   the quadtone
printing stuff that I've been working is all with the standard
stable version of gimp-print i.e. 4.2.x  (latest is 4.2.5).
I'm just putting the finishing touchs of packaging it up for
easy installation and use.  I've done it all on Mac OS X but
I am working with someone to get in running on a Linux
system.
Roy
2003-02-17 by Ernst Dinkla
Paul,
7500.
> >Quick work!
to produce.
fairly
inks and have
I wrote them ten days ago that I would like to order a pint set
as soon as the formula was finished. They wrote back that I
should wait for the announcement on the website. Any idea how
long it will take ?
Ernst
Sent: Monday, February 17, 2003 2:47 AM
of a
> slightly more
inkset.
> Factors
VM
> 4.3 inkset.
older
> inkset
that
probably
more
> ink per
spit
Arc-K.
One of the few things that actually change in the 9000 to 9500
upgrade is the firmware. There are new hardware parts installed
but that is only to get rid of the old inks, the hardware parts
are the same 9000 parts. In the firmware there's an extra
cleaning setting + a higher voltage/frequency for the heads +
possibly other changes we are not aware of. At least the
identity: the XP 9500 Epson status monitor will not accept the
9000 as a substitute for a 9500, trying that right now so it may
be my fault. Can't find the 9000 Status Monitor for XP so far.
The paper settings in all the Epson drivers have a special
inklimit per setting. The variation is not that much however. In
the Wasatch SoftRip that I have you have to set that limit
yourself and then it is quite easy to get a far higher density of
the black and depending on the paper more or less bleed. So
having a 7000 or a 9000 doesn't mean that the max ink amount
printed is so hardware/firmware limitated that you can't use it.
GIMP-Print should be the cheap way to get a maximum inklimit
setting possible for a given ink/paper combination. My guess is
that the new UC + clones will bleed less due to the viscosity
difference and so the inklimit can be set higher than with dyes
or the first generation third party pigment inks.
In the 9000 Epson driver the 1440 settings give slightly more
black ink than 720 dpi, speed doesn't make any difference and
Photo Quality Glossy Paper gives a higher black density than
SemiGloss Photo paper. There's however more UCR or GCR done in
the Photo Quality Glossy paper setting so for colour printing so
this choice isn't always the nicest but hard edge colour printing
gets better with the PQGP setting including large black areas.
I've measured the differences for black only on German Etching
but do not have the absolute figures anymore. All minute
differences if compared to RIP inklimit changes.
Linux
'repaired' was
second
Bah-humbug!
Had the same experience with a Suse trial maybe 2 years ago. In
the end I did a low level format of the disc on an Acorn Risc Os
machine, after that it was easy to get it ready for Windows
partitioning again. It is possible to get rid of it with other
means but I don't recall how. It should be in the Suse manuals.
Ernst
2003-02-17 by Johnny Eades <jeades1@sc.rr.com>
Hello Steven K.
If you still have the Linux boot loader, just dig out an old Win95
or Win98 boot floppy and run fdisk /mbr and reboot. Voila! No linux
boot loader.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
Karafyllakis <stevek@e...>" <stevek@e...> wrote:
> Hi Paul;
UC
> VM 4.3
a
> slightly more
inkset.
> Factors
> 4.3 inkset.
older
> inkset
probably
> ink per
to
Gimp-
printers
was
4.3.4;
B&W
> experiment
> Steve K
Ernst,
>> ... latest version of the VM inkset running on the 7500.
>> ... I think MIS is fairly
>>are MIS inks and have been thoroughly tested.
>long it will take ?
I don't know when MIS will be ready to sell the mix.  When you wrote to them
10 days ago things were much more unsettled.  My use of the Epson Archival
black in a couple of formulas turned out to be a mistake.  It faded and
messed up the rheology of the inkset.  This new mix, by staying with an
inkset that is made to work together, avoids the rheology problems, and the
MIS UC clone inks do very well in the fade testing.
>upgrade is the firmware. ... In the firmware there's an extra
In looking at the dots under a loupe, I can barely see the light gray in the
highlights.  However, further down the ramp, but still where the only ink in
the "warm" curve print is the light gray (which is in the yellow ink
position -- no built-in cross-overs), I see some roughness.  So, I think
that the main thing I'm seeing with my nose in the test strips is a dither
pattern.
> At least the identity: the XP 9500 Epson status monitor
>will not accept the 9000 as a substitute for a 9500, ...
When I use the 7000 diver with the 7500, the status monitor doesn't work.
This isn't a big deal to me, as long as use of the 7000 driver is not doing
any damage to the printer.
>inklimit per setting. ...
With the 7500 driver the best/darkest black was the Watercolor - Radiant
White.  With the 7000 driver, Mike Kravit did quite a bit of experimenting
when we worked on the first set of vm curves and found that the Photo Paper
setting was the smoothest.  I find that on the 7500, the 7000 driver set to
Photo Paper gives a black that is as good if not a hair better than the
7500-Watercolor setting.  I get 1.68 with MIS 7600 Matte Black (probably the
same ink as PiezoTone Museum).  Given the outstanding fade characteristics
of this/these inks, I'm very happy with this level of performance.  It's as
good as I was getting with the 3000 and MIS VM/FS black with the old EAM,
and noticeably better than I can get with the new EAM/EEM and VM/FS black.
I hope the computer guys can get this running for us PC users.  It sounds
most interesting.
> In the 9000 Epson driver ... Photo Quality Glossy Paper
>gives a higher black density than SemiGloss Photo paper. ...
That is the paper setting I used for 9000s also.  With the 7000 driver and
the 7500, it looks like Photo Paper is just a hair darker than PQIJ.
>... All minute differences if compared to RIP inklimit changes.
Yes, I'm sure that is the case.  I'll be curious what kind of black dmax you
can get with your RIP when you get these inks.
With the 7000 I noticed those running the PiezoPro driver were achieving
deeper blacks than the Epson driver could produce with the 7000.  I assumed
the 1.7 range the PiezoPro was achieving with PiezoBW K (essentially the
same as MIS FS-K) on old EAM was about the limit of what that paper could
hold.  This is good, but not enough of a difference from the 1.68 the 3000
and now 7500 can get to make me spend $1500.
2003-02-18 by Steven Karafyllakis <stevek@evcom.net>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ernst Dinkla"
<> Had the same experience with a Suse trial maybe 2 years ago. In
> Ernst
In the interest of saving others a lot of trouble, this is the easy
way to get of the Linux bootloader:
A) boot your system with a Windows 98 bootsdisk, or any other
bootdisk that has FDISK on it.
B) When you get to the DOS prompt, type in :  fdisk/mbr  and hit
enter.
The next time Win boots up it'll put up a notice that the boot-
record is missing, so it has to boot from a previous profile. Let
it. That's all there is to it, I wish I had trusted the info when I
first got it, it would've saved me a whole lot of time.
Steve K
SV: [Digital BW] Re: Epson 7500 what inks should I use?
2003-02-18 by Sören Lindqvist
long it will take ?<
This is the answer I got from MIS
As soon as we know it has good fade resistance.  It takes a couple of
weeks.
Soren
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=245454.2895241.4313951.2848452/D=egroupweb/S=1705
019182:HM/A=1457554/R=0/*http:/ipunda.com/clk/beibunmaisuiyuiwabei>
<http://us.adserver.yahoo.com/l?M=245454.2895241.4313951.2848452/D=egrou
pmail/S=:HM/A=1457554/rand=575179047>
same page.
keep them short.
header.
<http://docs.yahoo.com/info/terms/>  Terms of Service.
