Black Only - Not just a dot issue
2003-02-13 by plnelson2003 <peter@studio-nelson.com>
I've been doing some more experiments with black only and I've run into another technical issue. (When I get back from my vacation I'll put this on my webpage with some sample images but here's a summary). As I mentioned before I've been user-testing Black Only. I tried it on my wife's musician friends with mixed results - some people could see the dots and found them annoying; most people couldn't see the dots and those people liked the prints. So today I took some sample images to work where I showed them to my fellow engineers. (My company makes systems used for high-end image display used in medicine and scientific research.) And they complained about something the musicians hadn't noticed - mach banding, especially in the wedges. The problem is this. These were printed with the output resolution set at 300 Pixels Per Inch in Photoshop, which is a pretty common number to use when printing photographs. 300 PPI corresponds to 90,000 pixels/square inch of printed output. The 2200 is capable of 2880x1440 DPI, i.e., 4147200 dots/square inch. So the printer driver has 47 distinct values (i.e., 0 dots of black to 46 dots of black) to use for each pixel in the supplied image. But that pixel could be 0 to 255! And, anyway, 46 is not NEARLY enough to avoid mach banding! The human eye needs a minimum of closer to 100 distinct levels to see smooth transitions. But the mach banding is not as bad as what you would get with 46 levels, so I'm assuming the driver is trying to be smart and integrate over adjacent pixels in the image. (most modern drivers do not just operate one pixel at a time) This is fine as long as we remember that ALL dithering algorithms are a tradeoff between spatial resolution and value or color resolution. You gain one ONLY at the expense of the other. If the driver is integrating over two pixels it could be cutting the resolution in half. Based on the banding I see, it looks like the Epson driver is trying to compromise between these two cases. A test for this would be to print adjacent black lines, 1 pixel of white dividing them at 300 pixels per inch. The printer SHOULD be able to print them as two distinct lines given its 2880x1440 DPI resolution. Now try two gray lines, or two black lines with gray in between them. I'll do all this when I get back and post the results on my website. This may explain why some people say that Black Only seems too contrasty. It just doesn't have enough levels to play with to make subtle gradations. If my math is right, using black ink plus light black ink (pretending for a moment that light black ink isn't brown) assuming that light black has roughly half the pigment as black, would yield 93 values, above, where we had 46. Obviously all these numbers would be much worse with lower resolution printers. This also raises the interesting prospect that we can manipulate the number of gray levels the printer uses by varying the Pixel Per Inch setting in Photoshop. However, depending on what they do internally, it's hard to predict WHICH numbers would give us the best results. Also it would almost certainly vary from one printer model to another, because the drivers would be different.
