Re: [Digital BW] Two Amazing Things
2003-02-14 by Ernst Dinkla
Sent: Friday, February 14, 2003 8:29 AM
Subject: [Digital BW] Two Amazing Things
> The 2nd amazing thing is when I thought about the fact that I'm
> printing BO, and how the printer changes the spacing between the dots
> to get the various shades.  It's one thing to do that at the upper end
> where you can see individual dots getting closer or further apart, but
> how does it do it down at the dark end?  How in the world does it make
> a solid tone, so dark there are no distinguishable dots, a bit darker
> when I change a value by a half an RGB unit?  Does it still "think" in
> terms of individual dot spacing, all of them ever closer together and
> overlapping, or does it know that at some point they are all
> overlapping and it just changes the amount of ink it lays down?
> However it does it, it's incredible.
It uses 3 droplet sizes as well next to the stochastic dot distribution.
Ernst
RE: [Digital BW] Two Amazing Things
2003-02-14 by Alessandro Pardi
Hello Clayton,
I surely agree that by going digital we have a terrific control on what we
do (without mentioning the capability of easily undo what we don't like - at
least until the image is on the monitor).
I must add, though, that changing by 1% the 5% and 95% points isn't simply a
1% change, because it also affects all intermediate values (except, I'd say,
for the median), especially because the two changes go in the opposite
direction, thus enhancing the contrast. Also, how much impact this can have
depends on the image itself (if many areas of the picture are around the
changed densities, the difference will be greater). All summed up, I think
it's not correct to compare this to a dodge/burn in the wet darkroom.
Just my 0.02 euros,
Alessandro Pardi
Sent: venerdì 14 febbraio 2003 8:30
Hello All,
I was getting ready to make some prints this evening from an image I'd
previously worked up and considered finished.  After the first print I
felt it needed a tad more contrast, so I decided to use a transfer
curve until I had it worked out to my satisfaction, before I changed
the image.  After a few trials I ended up changing each end by 1% -
the 5% point became 4% and the 95% point became 96%.  This added just
the right amount of extra kick it needed.
I then decided to permanently alter the image by adding the same curve
in a layer, flattening and saving it.  The transfer curves are scaled
in % units and the adjustment curves are in RGB values, so I used a
calculator to make sure I entered an identical curve (each 1% is equal
to 2.56 RGB units).
As I was doing this I was thinking about yesterday's thread where I
said I could see the difference in a print with as little as 2 RGB
units change.  That was a general statement from memory and an amount
I felt confident saying in public.  I had never actually done any
exact testing to see what degree of change could be detected.  I
realized that my 1% change (2.56 RGB units) had made a clear
difference in the print.
While entering the curve points I discovered I could not enter the
exact values because you can only enter integers, not fractional
values.  So instead of 2.56 RGB units I had to change the points by
either 2 or 3 units.  I chose 3 for the dark end (moved the 13 point
to 10) and 2 for the light end (the 243 point to 245).  The first
print came out looking a tiny bit too heavy in the blacks, so I
changed the dark end to a difference of 2 (13 to 11).  This time it
was a tiny bit too light  (compared to the transfer curve print which
was a difference of 2.56).  It was still darker than the original so I
decided to stick with that and flattened it and saved the file.
It suddenly dawned on me that a difference of one half an RGB unit was
detectable in the print.  Including the transfer curve print, the 95%
points in the three prints were increased by 2, 2.56, and 3,
respectively.  The difference in all three prints, while subtle, is
clearly visible.  That, to me, is amazing.  What an incredible degree
of control we have.  One half RGB unit is equivalent to about .2%
To have that degree of control with an enlarger we'd have to have the
light stopped down to a 500 second overall exposure for the print
(over 8 minutes).  This would allow us to dodge or burn for 1 second,
giving us the .2% adjustment.  The numbers work out ok, but in
thinking back to darkroom work, I doubt that burning for 1 second out
of an 8 minute exposure would yield a noticable difference.  Perhaps
the paper is not sensitive enough to show it.  Is my thinking off
here?  Anyway, it's interesting.
I'm a programmer, and I understand the principles by which all this is
done,  but I'm still in awe of it.
Clayton
http://www.cjcom.net/digiprnarts.htm <http://www.cjcom.net/digiprnarts.htm>
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint>
page.
them short.
- Good manners are required at all time. No personal attacks or
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
2003-02-14 by Johnny Eades <jeades1@sc.rr.com>
Hello clayton,
Your amazing thing #1 is just what we were talking about a few weeks
ago when I first started BO printing and had to create a transfer
curve for the back end to change the "room at atalaya scene" so the
fireplace would have a printable black and not blank black and
change the shutters so there was some detail in the slightly darker
area. (Whew! Long sentence that probable needs puncutation!!) In the
eamil I sent I said "I have re-read your articles and with the help
of another group member who dumbed it down for the old man to
understand. I now use the front end of Gamma Gray 2.2 and have added
a transfer curve on the back end of 50=55% 70=65% 80=75% 90=85%  to
get the print to match the screen image." You mentioned that you had
printed the image just straight and if you had made the changes I
mentioned yours would have come out differently than mine did. You
added that the only time I would need a back end curve was to adjust
for different paper. Evidently my printer is not a very good printer
for doing these things, but when I made the back end transfer curve
it brought the lower values up enough that the image as printed
matched my screen image. And my monitor is calibrated, so I guess
this transfer curve calibrated the printer to match the screen
image. WYSIWYG? Maybe we need to talk more often, it seems like we
both have ideas on this subject. Yours are scientifically based and
mine are by the seat of my pants.
> From: Clayton Jones <cj@c...> [mailto:cj@c...]
> Hello All,
I'd
print I
changed
just
curve
scaled
equal
> to 2.56 RGB units).
amount
point
which
so I
was
95%
degree
second,
out
Perhaps
dots
end
but
make
darker
still "think" in
and
this is
> Regards,
> Clayton
Polls and
wish to
this same
> page.
to keep
> them short.
header.
various
Hello clayton,
> Hello All,
I'd
print I
changed
just
curve
scaled
equal
> to 2.56 RGB units).
amount
point
which
so I
was
95%
degree
second,
out
Perhaps
dots
end
but
make
darker
still "think" in
and
this is
> Regards,
> Clayton
Polls and
wish to
this same
> page.
to keep
> them short.
header.
various
2003-02-14 by Clayton Jones <cj@cjcom.net>
Hello Alessandro,
>All summed up, I think it's not correct to compare this to a
Excellent points, thanks very much.
Clayton
