Anti-Flaking Surface Protection
2003-02-14 by Roger Sopher <rlsopher@comcast.net>
A while back there was discourse about overspraying prints in order to reduce/prevent flaking of the coating. One of the questions I had was whether or not overspraying would cause changes in density or color. I bought four different cans of Krylon products - Workable Fixatif, Low Odor Matte, Kamar and Ultraviolet protective Clear. I printed a step wedge on Eclipse Satine 190 in two positions per sheet using MIS FSN Quad using an Epson 860 with a MIS CIS. One of the step wedges was spayed on each sheet using one of the products and allowed to dry. The steps were then read with an ESECO CompuMaster reflection densitometer. The Low odor Matte is not useful for this pupose. It produces a yucky platic appearing surface. It also tended to spray unevenly since it is latex based and fairly thick. The Kamar went on evenly and did not produce a noticible coating but it did cause a significant increase in densities particularly at the high end of the curve. 25% - 0.3, 0.37; 50% 0.59, 0.77; 75% - 1.01, 1.27; 100% - 1.54, 1.68 UV Resistent Clear is an acrylic based products that went on evenly and did not produce an obvious coated look. It also produced an increase in density but not quite as much as Kamar. 25% - 0.3, 0.36; 50% - 0.59, 0.71; 75% - 0.99, 1.16; 100% - 1.53, 1.56 Workable Fixatif went on evenly and did not produce an obvious coated look. It produced no significant change in density along the scale with the differences being only + or - 0.01 which is the limit of reproducibility of the densitometer. To my view the workable fixatif might be the preferable product to use since it produced no significant change in densities. I'll add Lyson Print Guard and Lascaux Fixativ (if I can swipe it from my wife's studio) to the list but with the Krylon products being less than one third as expensive I hope the Workable Fixatif ends up being a winner. The next step will be to put these in a south window and let the New Mexico sun do its thing for a month to check for yellowing and the like. Roger
