burning in photoshop
2003-02-14 by digikdm <monroekd@healthall.com>
Has anyone noticed that when you burn a B&W image in an RGB format
that the burned area takes on a yellowish hue? This of course doesn't
occur in greyscale mode, but my scans are usually in RGB mode, and I
usually work in RBG to maintain the option of colorizing portions of
the print at some point.
Re: burning in photoshop
2003-02-14 by Jim Respess
<Has anyone noticed that when you burn a B&W image in an RGB format
the print at some point.>
I have not noticed a hue change in burning but I have some suggestions:
	1.  Try making a new layer; change the mode to soft light and
paint (at some reduced opacity) with black to burn or white to dodge.
I get much more control that way.
	2.  Work in grayscale and when you want to colorize change mode to RGB.
	3.  Desaturate after burning.
Cheers,		Jim
James G. Respess
Green Flash Photography
858-272-1926
See my art at:  http://www.greenflashphotography.com
Gallery at:  http://offtrackgallery.com/gallery/respess.htm
RE: [Digital BW] burning in photoshop
2003-02-14 by Seth Rossman
If you are using the burn tool, try going to the History Brush instead.
Better control also.
Seth
=Subject: [Digital BW] burning in photoshop
=Has anyone noticed that when you burn a B&W image in an RGB format
=that the burned area takes on a yellowish hue? This of course doesn't
=occur in greyscale mode, but my scans are usually in RGB mode, and I
=usually work in RBG to maintain the option of colorizing portions of
=the print at some point.
2003-02-15 by Harry Saddler
Another alternative to burning: select an area, go to quick-mask mode, do
a gaussian blur of the mask, switch back into normal mode, then do a
Levels adjustment layer. If you need the effect to fade from one side to
the other, or from the middle out, you can apply the gradient tool over
the adjustment layer. The common photographer's trick of slightly burning
in the corners of an image is easily done this way; use the oval
selection tool, select the entire image except for the corners, invert
the selection, then continue with the quick-mask as above. The cool thing
about this is that once you've got the mask created and appropriately
blurred, you can then drag the levels slider back and forth while
watching the strength of the effect. Other selection methods are good for
this, too, e.g. color range.
>Seth
>Please visit the Group Homepage to check the Files, Bookmarks, Polls and
>other resources as they are often being updated. The page is at:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to
>unsubscribe, please edit your Membership preferences by visiting this
>same page.
>Please follow these basic guidelines:
>- Include your full name with your message.
>- Include the address of your website, if you have one.
>- As threads develop, trim off excess portions of earlier messages to
>keep them short.
>- As the topic of a thread changes remember to change the subject header.
>- Good manners are required at all time. No personal attacks or
>&amp;amp;quot;flames.&amp;amp;quot;
>- Complete your Yahoo profile.
>- Before posting a question, search the message archives and the various
>resources on the homepage.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Harry Saddler | hsaddler@...
Re: [Digital BW] burning in photoshop
2003-02-15 by Carolyn Frayn
> do
> to
good tips... another way to do that is to make the levels adjusment
layer first, make your selection, hit the mask icon while the levels
adj layer is highlighted and then blur the mask, just the way I prefer,
rather than going in and out of quickmask.
Try putting the levels adj layer with it's mask into a curve set, then
apply  another mask to the set, double masking... life doesn't get any
better... until the filter adjustment layers hit us in PS8.
> thing
> for
another is make a levels or curve layer, don't make any moves in it,
it's acting like a dup image layer without adding file size, put a
multiply blend mode on it, mask the layer and paint white and black to
effect the areas required.  You can also of course make moves within
the adjustment layer to further emphasize what you're doing.
Try the screen blend mode for dodging.
dodge burn tools in PS, in my opinion, are too destructive to most
images.  but the various ways to accomplish it without using them are
very cool.
Carolyn
2003-02-15 by Bobbo
To control burning and dodging in Photoshop, Jim suggested:
Try this also and see which you prefer.
1) select the layer.
2) Create a new layer. Select "Group with Previous Layer" checkbox. Set
mode to OVERLAY and check the box that fills the layer with 50% grey.
3) Press D to reset colors to black and white. Now just paint with a
paintbrush! It's simple. White dodges and black burns -- use the X key to
switchback and forth. Use around 20% for faster work, 10% or lower for more
delicate work.
Just do your dodging and burning on the new layer. As in Jim's method, it
remains completely workable. I was reminded of this method at the Epson
Print Seminar, so thanks to Vincent Versace. He used the eraser tool, but
my head feels straighter using the brush for some no doubt neurological
reason. Click the airbrush and see if you like the feel any better. Big
difference for me is that dodging seems to show up a lot faster in Soft
Light, while burning takes a bit more time, but both work fine.
Another cool method is to dupe the layer, change levels to darken it
considerably, and then use layer masks to let the lighter one show through.
Again, since a layer mask is being used, the effect remains workable and is
quite nice. You can also use any method to shift the color cast on the
duplicated layer. So, for instance, if want your shadow areas warmer for
some reason, just shift the darker image toward the warms a wee bit, or use
a hue/sat adjustment layer to warm it up, paint in the layer mask, and let
your cooler highlights show through.
Bobbo
Artwork and Nature Photopaintings -- http://www.bobbogoldberg.com
Voice over demos and services -- http://www.bob-vo.com
2003-02-15 by Clayton Jones <cj@cjcom.net>
Thanks, folks, for all the really good tips.
Clayton
2003-02-16 by Stephen Kobrin <skobrin@hotmail.com>
One more thing:  when you add the soft-light layer make sure it is
medium gray.  You can vary the opacity and size of the brush and get
great control over the process.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jim Respess
doesn't
suggestions:
dodge.
mode to RGB.
> Cheers,		Jim
> James G. Respess
> 858-272-1926
2003-02-17 by Tom Andrews <tandrews@boulder.net>
I do something that I think may be similar to below.  I make a selection of the
general area I am interested in burning or dodging.  Then I make a curves
adjustment layer of the selection and lighten or darken to get the main effect
I want.  Then I reload the selection, go into QuickMask, and paint around the
edges in combinations of black and white with variable opacity and size
brushes until I get the seamless blend I am looking for.  Or apply a gradient
to the QuickMask. Then resave the changed selection to replace the previous
one.  Nice thing about doing it this way with an Adj Layer is, of course, that
you can go back and change it anytime you want, which you can't do with the
burn and dodge tools, once you have closed and reopened the file.  It also
gives very accurate and controlable lightening and darkening without hue
shift.  I do this a lot.  I also use the dodge and burn tools a lot for really small
areas.  I will need to try the refinements? below.
Tom Andrews
http://www.wildlandart.com
RGB.
more
> delicate work.
use
> Bobbo
