Re: [Digital BW] Digest Number 1313
2003-02-14 by Scott Jolliff
On Friday, February 14, 2003, "digikdm <monroekd@...>" <monroekd@...> wrote: > Has anyone noticed that when you burn a B&W image in an RGB format > that the burned area takes on a yellowish hue? This of course doesn't > occur in greyscale mode, but my scans are usually in RGB mode, and I > usually work in RBG to maintain the option of colorizing portions of > the print at some point. I haven't experienced what you mention but try darkening the entire image with a new brightness/contrast adjustment layer. then fill that layer in with black (edit>fill...) and then paint the areas you want burnt down with white. I like to darken more than I need and control the burning with the transperancy setting of the brush that I'm using. (I never use the burn tool. I like the results from this method far better). Scott Jolliff Jolliff Productions, Inc, http://www.jolliffphoto.com O: 404-351-7468 M: 404-314-8632 Stock represented by, http://www.mira.com
