problems with MIS cartridges
2003-02-16 by parrellacorrado <corrado_parrella@biotec
I tried to employ MIS cartridges on my 1290 EPSON printer in order to
have a quality B/N printout. I received two sets one QFS and one QVM.
The QFS one has the black cartridge not recognized by the printer
driver, the QVM one after five printouts (quiet good) seems to be
empty even if the level displayed is at 75%! MIS e-mailed anwers that
they can change the products.
Does anybody have had such experiences with MIS product?
Is MIS product a good choice for B/W quality prints?
Thanks for an answer.
Corrado
Re: problems with MIS cartridges
2003-02-16 by jim hayes <jimhayes@frii.com>
I can only partially help. Your problem may be due to other causes but
here are some thoughts-
When I used a 1280 and filled my own carts with VM ink, I never had
problems with ink running out too early. However, the chip that MIS
sells separately to assemble onto the cart was, unlike the ones on
Epson carts, suseptible to getting zapped in two different ways: 1) In
handling, either through touching with my finger or under physical
force when installing onto cart; 2) Much more common, the chip can
lose it's "mind" if cart is inserted into printer with power on. Then
the ink status will never again read properly for that chip. The
solution is to touch grounded metal before handling chip, and to turn
printer off (letting head return to right position, press off button)
and UNPLUG. Wait one minute. Then press down on white vertical post
near bottom front left of printhead (or an alternate method which I
haven't tried is to turn the white gear on the back left of printer)
and release the printhead, dragging it all the way to the left. Swap
out cart for the MIS cart and push head back to right. The white post
won't pop up again though until you plug in printer and turn it back
on.
Cutting power to printer is not nessecary if installing the chips that
come on real Epson carts, I've found.
When I bought prefilled carts from MIS, and I only bought one or two
sets in my experience, I had a problem with one color cart which ran
out of ink when the ink level from the chip was at about 30% left.
Since then I just kept filling my own carts using the vacuum fill
method. I wrote up a procedure on how to do this which is quite
lengthy I'm afraid<g>. It is in the file section of this group as a
pdf. It really isn't hard to learn, and after you invest in  all the
reusable stuff to fill yourself, I calculated that I could make my own
carts for 1/2 the cost (US) I could buy them from MIS.
MIS IS a good choice. Paul Roark has worked up a great set of curves
and inksets, although I gather that he is off now on the next
generation which will be offsprung from the idea of the new Epson
Ultrachrome inks. I am not an expert in how the new generation is
coming along as I have some current restrictions as to what ink works
in my environment.
My impression of MIS, and this is only a personal one, is that it is
the way to go for those that don't mind "hands-on" experimenting a
little more, in the way of both tweaking Paul's curves to taste, maybe
filling your own carts , having to do a couple of extra steps now and
then, etc. Other solutions like Piezo or Epson2200/ with Imageprint 5
have more of the work done for you. Of course one good thing to MIS is
that you can buy just about ALL the small parts that go into their
products: if you want to mix your own ink or build your own bulk ink
delivery system to printer, you can. And MIS will be a little cheaper
than other solutions. Customer support is very good.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "parrellacorrado
to
QVM.
that
> Corrado
2003-02-17 by parrellacorrado <corrado_parrella@biotec
Dear Jim
thank You very much for your skilled answer, I think I will go on
with MIS products; now i'm expecting the products back form MIS and
some explication by them.
Best regards.
Corrado
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jim hayes
but
In
Then
turn
button)
printer)
Swap
post
back
> on.
that
two
ran
own
curves
works
> in my environment.
is
maybe
and
5
is
ink
cheaper
> Jim H.
> --- In
order
> to
> QVM.
> that
> > Corrado
