UC VM 4.3 (was Epson 7500 what inks should I use?)
2003-02-17 by Paul Roark
Jerry,
>what is the MIS VM 4.3 inkset?
It's my latest mix.  I suspect MIS will produce it soon.
I basically needed an inkset for the 7500 that was up to date.  The old vm
didn't quite meet my current criteria.
My first attempt on the 7500 was a dual-black, vm-s inkset (Museum black in
the K spot, Epson Archival black in the cyan spot).  This arrangement
allowed software switching of the blacks to print on RC paper.  That aspect
of the inkset worked fine, and I'll probably put together a vm-s inkset that
uses the dual-k approach in the future.  The concept works -- RC and matte
printing without the hassle of switching blacks.
However, the Epson Archival black-based inkset failed for two reasons.
First, diluting the Epson ink with the clear bases that were available to me
changed the rheology (viscosity, etc.) of the ink such that I had banding.
Second, the Epson Archival black-based inkset, in the midtones (which were
diluted Arc K) faded and warmed about like the old diluted MIS FS-K.  This
is not the level of performance I was looking for.
So, I needed a good inkset fast, since I have a lot of printing I need to
get to.  The MIS VM inkset works very well on the 7000, so I decided to just
update that inkset.  The MIS UltraChrome clone Photo and Light black inks
were ideal for this.  They are extremely lightfast and also RC compatible,
for those who care.
So, UC VM 4.3 is an updated VM inkset that uses the same curves, is much
more lightfast, and is RC compatible (if Photo black is used in the K
position).
While I was at it, I tuned the inkset (pigment toner) to match my
lightly-selenium-toned silver prints when the "NC" curve is used.  The nc
curve produces prints that are just like the PiezoTone Selenium prints.
The "warm" curve, which prints with, essentially, the raw MIS UC Light Black
ink (pure carbon -- no color added), gives an image that is about twice as
warm as the old MIS VM inkset.  The CMY distribution is almost identical to
the old albumen prints (based on a good reproduction from the Getty of a
19th century Gustave Le Gray print), but with less saturation than the Le
Gray re-production.  It is not a full-on sepia, but a very nice warm tone
that is so close to the light sepia I was using that I'm not sure I'll need
any more.
So, for me, it hits the tones I need right now.  The nc curve matches my
silver prints, and the warm curve gives me the tone I need for the old photo
reproductions I'm involved with.  Most importantly for me, it works well in
the 7500 and is very light fast, so the prints I make are going to have a
good long life.
I'd be curious about your reaction to the inkset.  Each curve will print a
little warmer than the current vm inkset.  However, you have a "cc" curve
that should still be ice cold.
http://www.PaulRoark.com
Re: UC VM 4.3 (was Epson 7500 what inks should I use?)
2003-02-17 by Vincent Orlando <orlandovl@hotmail.com>
Paul, will these inks work with a 1200 using the 1200 curves?
Vinny
http://www.wulfsden.com
<paul.roark@v...> wrote:
> Jerry,
old vm
black in
arrangement
That aspect
inkset that
and matte
reasons.
available to me
banding.
(which were
K.  This
need to
decided to just
black inks
compatible,
> for those who care.
much
K
> position).
The nc
prints.
Light Black
twice as
identical to
of a
the Le
warm tone
I'll need
> any more.
matches my
old photo
well in
have a
> good long life.
print a
curve
> Paul
