ImagePrint Mini-FAQ
2003-02-19 by Thomas Fors
Here's a bit of a mini-FAQ in an attempt to answer some of the ImagePrint questions arising on the DigitalBW list lately. If anyone cares to tackle some of the larger questions (such as installation or proofing issues), I'd be happy to start compiling it into a comprehensive FAQ and host it in the Files section of the ImagePrint group. --Tom ----- Is there a demo available? Rumor has it that there once was a demo CD, but it did not work properly so ColorByte decided to discontinue it. There has been no word from ColorByte as to whether the demo will be fixed and offered again at a later date. ----- How does IP deal with metamerism on the 2200,7600,9600? Using the "gray" profiles for B&W printing, apparently IP does not use the yellow ink. A close examination of a very light gray printed patch reveals the only inks in use are Black, LtBlack, LtCyan, and LtMagenta. This results in a neutral gray print that exhibits no noticable metamerism under various lighting conditions. By adjusting the quantity of LtCyan and LtMagenta, IP offers the ability to tone your B&W prints using a tool called the TintPicker. For color printing, ColorByte provides four profiles for each paper type: Daylight (EDAY), Tungsten (ETUNG), and two Flourescent profiles (ECWF, ECWF2). You print with the profile appropriate for your target viewing light. This doesn't eliminate metamerism, but does allow you to create very color-accurate prints for a specific display environment. ----- How can I test my prints for metamerism? Here is how I test my Epson 2200 prints. The same or similar method may work for you. Metamerism is easiest to notice when looking at a grayscale image. 1. Create a grayscale ramp or step-wedge in Photoshop and print it possibly along with some grayscale images. 2. Allow the print to dry. 3. Find a room filled with flourescent lighting that has a window that allows daylight in. 4. Turn the print back and forth between the window light and the flourescent light. If you see a shift in tones between the different light sources, this is metamerism. For example, my 2200 prints using the Epson driver shift from green in the daylight to magenta under the flourescent lights. ----- Is ImagePrint hard to use? Yes, initially. There are some quirks in the user interface that make it a bit difficult to learn, but once you get past these, it becomes quite usable. ----- Are the ImagePrint profiles any good? They are excellent. ----- Where can I get more information? Try Colorbyte's web page http://www.colorbytesoftware.com/ or call them at (813) 963-0241. Try the ImagePrint yahoo group at http://groups.yahoo.com/group/ImagePrint/ -----------------------------------
