dot size in Black Only Printing
2003-02-19 by Johnny Eades <jeades1@sc.rr.com>
I currently have a Canon s750 which prints black only in 600 x 600
dpi. If I were to upgrade to a Canon i950 which prints black only in
4800 x 1200, would the dot size change or would there be any
noticeable difference? While on the subject of printers, what does
the 4800 x 1200 mean and what directions on the paper do those
numbers correspond. Is it 4800 dpi vertical or horizonal, and what's
the diffence in different dpi on a Canon i950 and the Epson 1280 at
a different dpi?
The reason for the inquiry is related to Black only photo image
printing.
Re: dot size in Black Only Printing
2003-02-19 by plnelson2003 <peter@studio-nelson.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades
in
what's
> a different dpi?
As far as direction - the manufacturer's website should have the
spec's but my guess is the 4800 is horizontal and the 1200 is
vertical.
The resolution is NOT a good predictor of dot size.  Again this is a
question you should easily be able to answer from the manufacturer's
own spec's, but typically the drop size is a better predictor of dot
size - FOR A GIVEN PAPER - and the trend is for smaller and smaller
drop sizes as the technology has advanced.  The s750 has a 5
picoliter drop size; the i950 has a 2 picoliter drop size, so the
latter should give you a finer pattern.
