Re: Canon print head limitations? (WAS: Jon Cone's new B/W system)
2003-03-03 by Doug I.
One issue I have not seen addressed with the new Cone system is regarding
longevity issues due to the inherently different design of the Canon print
heads. My understanding is that Canon (and most if not all non-Epson
inkjets) are not making their print heads replaceable out of the goodness of
their hearts, but because they have to--the tiny electrical "heaters" that
force the ink out of their heads have a relatively limited life span...or at
least less than the expected life of the printer. (I am paraphrasing, but
Epson claims that their system based on the electrical deformation of a
crystal to squeeze out (variable) ink droplets will last the life of the
printer...so making their print heads non-replaceable by average Joes like
us is actually a FEATURE. Ha ha.)
In any case, does anyone have further info on exactly how long a Canon print
head can be expected to last with pro-level use?
Doug
> Date: Sat, 01 Mar 2003 12:54:45 -0500
> From: Rick Colson <colson@...>
> Subject: Re: Digest Number 1356
> Re: Jon Cone's new B/W system FYI
> From: "flyfishingusa2002
> Let's clear a few things up. First of all, Cone's new system is based on
> Piezotone inks which have a great reputation for NOT clogging. Second, the
> reasons for Canon are speed and the fact that a second head with color inks
> can be swapped out anytime. This means that you do not need a dedicated b&w
> printer. Think about it! Third, the removable head means that you can simply
> rinse it under running water to clean out any paper dust or ink residue.
> Fourth, printing through ICC profiles means no expensive RIP. And yes, there
> will be versions of the profiles and inks for Epson printers too, though
> they won't have the same advantage re: swapping heads. As to the Canon
> switch, I have an Epson 7500, 3000, 1160, 1270 and a 1200 but I might take
> another look at the Canons for the reasons mentioned.
> While I've been critical of Jon's past claims (read my posts) I have met
> with Jon about this system and everything he says about it makes sense.
> Let's give the guy a break and wait see. Sounds like this addresses all the
> old problems to me...
