Re: [Digital BW] Re: Gray Balancer Conflicts
2003-03-03 by Truman Prevatt
That just might fix it. When I was fighting with XP over the wireless
network adaptor, it connected to the computer via USB.  In theory any
USB device that has been installed can be connected to any USB port on
the computer - independent on which one it on when the drivers were
installed. That's the way it works on ME, on 98SE on 2000. But when I
went to plug in the linksys adaptor onto a different USB port it could
find the drivers and wanted to install again. It will only work on the
port it was installed on.
I think there are some significant issues with XP and it's USB support.
If you printers on a hub they are on the same USB port going into the
computer and if my experience is any indication the computer is getting
cofused.
Truman
disch7634 wrote:
>--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Peter Nelson
><peter@s...>" <peter@s...> wrote:
>>--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "disch7634
>>>It was the
>>>785 and the Gray Balancer software. My theory is that the gray
>>>balancer is trying to control the 785 in the same way it controls
>>the
>>>2200. What I don't know is if it is a combination of the 785,
>Gray
>>>Balancer and XP. I would have to try a different operating system
>>to
>>>find that out. The fact that you say that you run Win2k without
>>>problems would make me think that XP has some hand in the problem
>>as
>>>well.
>>That's why I was wondering what resource it was competing over.
>>It may not be the printer itself, but something like the
>>parallel port -vs- the USB port.   How are your printers
>>connected to the PC?
>I was thinking about the parallel port thing after you brought it up.
>I have both of my printers connected to the USB hub. Maybe if I would
>hook one of them up through the parallel port it might solve the
>problem. I'm going to try that tonight.
>Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- Include your full name with your message.
>- Include the address of your website, if you have one.
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- As the topic of a thread changes remember to change the subject header.
>- Good manners are required at all time. No personal attacks or &amp;amp;quot;flames.&amp;amp;quot;
>- Complete your Yahoo profile.
>- Before posting a question, search the message archives and the various resources on the homepage.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-03-03 by Diane Fields
The Epson printers do not do well on a USB hub--put them on separate USB ports.  Before I put installed XP and added 2 more USB ports, I installed my 1280 on parallel and the 2200 on USB and had no problems whatsoever.
Diane
  Sent: Monday, March 03, 2003 1:10 PM
  Subject: Re: [Digital BW] Re: Gray Balancer Conflicts
  cofused.
  Truman
  >>>It was the
  >>the
  >Gray
  >>to
  >>as
  >>>well.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
Given my experience with the network adaptor and XP I suspect it is XP
rather than the Epson. On my old box (ME ) I had a scanner, my 1280 and
my network adaptor and a cheap Cannon printer all sitting on a hub going
into a USB port. It worked fine.
The problem I had with the network adaptor had to do with XP seeming to
want to assign a specific USB port to a specific piece of hardware.
Truman
>Diane
Truman, I had my 2200 on ME before XP.  There have been many posts on other forums about the fact that Epsons often have trouble connected to hubs.  I honestly never tried it--but just installed to a separate USB port and put the 1280 on the parallel.  I have not had any problems installing them on XP though--both are on separate USB ports.
Diane
  Sent: Monday, March 03, 2003 1:37 PM
  Truman
  >Diane
              ADVERTISEMENT
On the earlier UBS controllers there were issues with the specs on the
signal levels. A couple years ago I got a cheap scanner (Umax I think
but anyway it was not a Epson)  for copying documents. It was actually
free when I bought my Dell.  The scanner could not set on a USB hub. In
fact it was flakey directly on a USB port on my Dell. Even on the port
on the Dell it wouldn't work half the time.  It turns out that after a
lot of talking with technical support at both Dell and Umax it was an
issue that the power levels were not sufficent from the scanner for it
to operate correctly. The solution was a powered USB hub to bost the
levels and it worked fine from then on.
I suspect this may be the issue with Epson printers and it really has
more to do with the chip set they are using to support the USB. In the
early day of USB there were so specification issues and some things
didn't always work right. Unless Epson implemented the USB protocol very
worng - I suspect they use someone elses chip set to connect to the USB
-  it is up to the computer to sort of who is who is on a USB port. In
fact many of the cards you buy have multiple ports on a single
controller. That's not all that different than a hub.
>Diane
>  ----- Original Message -----
>  From: Truman Prevatt
>  Truman
>  >Diane
>              ADVERTISEMENT
I just checked my 1280 installation paper--it says to install to a first tier USB port--if that makes any difference--I have no idea, hardware is not my forte (I can deal with any software LOL).
I have mine installed and just switch from 2200 to 1280 without any problems whatsoever.  I just got my computer back from an upgrade and clean install of XP this past week.  I installed the 2200 first--no problem.  I installed the 1280--and XP did attempt to install a driver, but I closed it,  used the downloaded XP/2000 driver from the Epson site and it installed perfectly.  I use the 2 printers without any problem at all.  Have you checked for the latest drivers?    I also have 2 printers installed to my laptop which only has XP home edition on it--and can also switch from printer to printer--altho' I only have one hooked up at a time.
Diane
  Sent: Monday, March 03, 2003 2:35 PM
  >Diane
  >  Truman
  >  >Diane
  >              ADVERTISEMENT
              ADVERTISEMENT
2003-03-03 by disch7634 <disch7634@yahoo.com>
Both of the printers are connected directly to USB ports on the
computer, I probably shouldn't have used the term "hub" although I
think that the computer only has one controller for the USB ports and
that's really the same as a hub anyway. I think connecting one
printer to the parallel port will solve the problem.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Truman Prevatt
think
actually
hub. In
port
after a
an
it
has
very
USB
In
ports.
> >Diane
is XP
1280 and
hub going
seeming to
hardware.
> >  Truman
> >  >Diane
> >              ADVERTISEMENT
is at:
subject header.
Service.
is at:
to keep them short.
header.
