Re: [Digital BW] Can I mix and match continuous ink system brand and inks?
2003-03-04 by Martin Wesley
From: <dcka@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, March 03, 2003 11:58 PM Subject: [Digital BW] Can I mix and match continuous ink system brand and inks? > Hi there, > > Question from a serious noob here, but here it goes. > > From past discussions here, it seems that the Noremorecarts CIS is > better in these respects: higher grade tubing, custom chip that never > needs resetting, and the ability to run the whole thing with the lid > more or less closed (bumpers that raise the lid just enough to clear > the tubing.) > > Given this, here's my question: can a Noremorecarts CIS accept MIS > ink sets? My assumption is yes, but I don't want to make any > expensive mistakes. :-) > Dimitri, You can use the Nomorecarts CIS with any of the ink sets available including all the MIS inks. I have been using their CIS on my 1280's for a couple of years now with MIS, Piezo and PiezoTone inks. Just be careful that the arm stays up and doesn't let the tubing droop. I added an extra Velcro strap on the right edge of the printer housing that goes over the top of the end of the support arm and tubes to keep it in place. Also watch out for the lid support bumpers coming loose and dropping into the printer. My only complaint about the CIS is that the adhesives they use don't stand up over time. Martin Wesley
