Re: [Digital BW] Mounting Oil was Re: Epson3200 - Test results/Kami
2003-03-05 by Ernst Dinkla
Sent: Wednesday, March 05, 2003 2:09 AM
Subject: [Digital BW] Mounting Oil was Re: Epson3200 - Test
results/Kami
> > For large negs consider using a cover sheet so that you have
a
> sandwich of
> > glass/oil/neg/oil/cover film. The cover film is taped to the
glass
> and you
> > can then use film wipes on the cover film to work air bubbles
out
> to the
> > edge of the negative.
> > Martin Wesley
> Would some cover material like a clear acetate be sufficent as
a
> cover film ? How is the negative cleaned after scanning ? Any
danger
> to the emulsion of the negative ?
> TIA
> Andre
Use transparant polyester for that. That is the same plastic the
film is made of. The prepress supply dealers have that too in
sheets or on rolls.
One warning if you use fluids on a flatbed: the surrounding
plastic housing is often made of ABS, it will degrade when it
gets in contact with the fluid. Few plastics withstand the
agression of aromatic fluids: polyester, polypropylene,
polyethylene, nylon, polyurethane, silicone and several more
exotic grades will not be affected or less affected. You have to
work very careful and not spill any fluid on the housing or put a
polyurethane (or silicone that can be removed ?) varnish on the
plastic directly surrounding the glassplate. Maybe a piece of
cling foil with a window cut out will protect it as well (if it
isn't a PVC product).
Professional wetmounting is a process. Antistatic air, adhesive
rolls to take dirt of film and glass, extra cover sheet, mounting
fluid, pressure roll.
There are ways to simplify that.
The housing of most flatbeds isn't strong enough to squeeze the
fluid from the sandwich with a roll, better use a polyethylene
squeegee and another sheet of polyester on top to avoid
scratching of the first polyester sheet. A tod at the end to
absorb excessive fluid. Find a good methode that doesn't need
tape to keep the polyester sheet in position. Tape always gives a
mess in the long run. For that reason I've made some small clamps
on my special Nikon 8000 wetmounting carrier.
If you have a register punch and a register strip you can put the
strip with two sided tape on the housing outside the glass or on
a non scanning part of the glass. For the 3200: there is a small
strip along the left side that isn't scanned. Punch the foil and
put it on the scanner. If you use the same spots the glassless
carrier uses then it is easy, put the carrier on top of that and
mark the window on the polyester foil. Take it off and you know
where the film has to be placed between polyester and glass.
After mounting you can put the carrier on top for scanning. If
you need other film windows then the punch and black paper masks
will make the process as easy. That is how I used to wet mount
film on the Agfa Horizon Plus. If you are handy enough then a
good! adjustable! office punch and a selfmade strip will do.
Don't use more than two holes on sheet sizes like this.
Ernst
2003-03-05 by Julian Thomas
One thing I'm now doing on my 1680 is to put the neg in-between a black card
mount, place on the platen with AN glass over the top 0 a big improvement
over the carrier and the card cuts down shadow 'noise'.
Julian
Sent: Wednesday, March 05, 2003 9:55 AM
Subject: Re: [Digital BW] Mounting Oil was Re: Epson3200 - Test results/Kami
> From: "sceptre12345" <am1000@...>
> results/Kami
> a
> > sandwich of
> glass
> > and you
> out
> > to the
> > > Martin Wesley
> a
> danger
> > TIA
> > Andre
> sheets or on rolls.
> Ernst
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
2003-03-05 by BMercerTX@aol.com
In a message dated 3/5/2003 5:38:53 AM Central Standard Time,
julianthomas@... writes:
Julian,
Could you explain this in a little more detail.  I'm not sure I understand
what you mean.
Thanks, Billie
The 1680Pro  is an A4 flatbed. Rather than oil mount - I use  a black card
presentation slide mount. Slide the neg into the card mount. Out on the
flatbed platen and then put antinewton glass over the top. In some scans
with high black areas without the card and putting straight on the glass I
was getting some noise. The card reduces this.
Julian
Julian
Sent: Wednesday, March 05, 2003 2:36 PM
> Julian,
> what you mean.
> Thanks, Billie
page.
them short.
2003-03-05 by Martin Wesley
Sent: Tuesday, March 04, 2003 5:09 PM
Subject: [Digital BW] Mounting Oil was Re: Epson3200 - Test results/Kami
> > For large negs consider using a cover sheet so that you have a
> sandwich of
> > glass/oil/neg/oil/cover film. The cover film is taped to the glass
> and you
> > can then use film wipes on the cover film to work air bubbles out
> to the
> > Martin Wesley
> Would some cover material like a clear acetate be sufficent as a
> cover film ? How is the negative cleaned after scanning ? Any danger
> TIA
Andre,
Companies that sell mounting fluids and oils such as Kami and Prazio also
sell cover sheet material which I believe is a polyester film. I clean my
negs with a spray film cleaner from Prazio and/or PEC. With the "vanishing"
type oils like Kami and Prazio Anti-Newton this is pretty easy as there is
minimal residue. With heavy oils it takes longer and more film cleaner.
Typically drum scanner drums are filled with multiple negs so they can run
overnight and may be in contact with the mounting oil for many hours without
ill effects.
If you do use a cover sheet you really need to use appropriate mounting tape
that is compatible with the oils and easy to remove. Once again this can be
purchased from the companies that sell the oil and cover sheets. You can use
the same tape to tape the edges where the glass bed meets the scanner frame
to help keep oil from running into the scanner interior.
Martin Wesley
2003-03-05 by sceptre12345
Thanks for your reply Martin. I've learn a lot with this tread.
With an Epson 3200 arriving in a few days, I'll certainly put into
practice what has been discussed.
Now I need to find a retailer for scanning supplies in Canada. I've
already emailed Access Imaging in Toronto but got no reply.
Andre
> Andre,
> Prazio also sell cover sheet material which I believe is a
> polyester > film.  I clean my negs with a spray film cleaner from
> Prazio and/or > PEC.  With the "vanishing" type oils like Kami and
> Prazio Anti-Newton this > is pretty easy as there is minimal
> can run overnight and may be in contact with the mounting oil for
> many hours without ill effects.
> mounting tape that is compatible with the oils and easy to remove.
> Once again this can be purchased from the companies that sell the
> oil and cover sheets. You can use the same tape to tape the edges
> where the glass bed meets the scanner frame to help keep oil from
> Martin Wesley
2003-03-05 by mh
Prazio is in Canada  (www.prazio.com)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sceptre12345" <
> Cheers,
> Andre
> > Andre,
> > Martin Wesley
Thanks mh, have just emailed them.
Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mh" <mh@t...>
