best of the LCD monitors
2003-03-04 by Dan Honemann <dan_honemann@yahoo.com>
I'm putting together a digital imaging system, and have pretty much
decided on a Gateway 700XL running WinXP.  The only question left is
which monitor: Gateway offers a 20" 1600x1200 flat panel for roughly
$1k.  Anyone using this?
I've read good things about NEC and Apple LCD displays.  Would I be
able to use an Apple monitor on my Gateway PC (it comes with a 128MB
ATI Radeon 9700G Pro AGP video card with DVI).
I know CRTs are a better choice for calibration, but I simply don't
have room for one in my workspace.
Thanks for any advice you can offer.  I'm able to spend up to $2k for
the monitor.
Dan
Re: best of the LCD monitors
2003-03-05 by jbtarnof
Dan:  I would stay away from trying to make an Apple display work on
a PC. Too much signal degrading through the adapter IMHO.
In your price range, you have some potent choices.
Here are what I believe to be the factors:
Contrast.  You want 500:1 or better
Luminance.  You want 250 or better
Dot Pitch.  You want as low as possible.  LCD's are still catching up
to glass.  The LCD threshold has been around .29, and in your price
range you'll be able to do better.
A few to check out:
CTX H2300.  Their top model.  $2100 on Tiger Direct
http://www.ctxintl.com/products/lcd_H2300.htm
Samsung SyncMaster 241MP/211MP
http://www.samsungelectronics.com/monitor/mfm/241mp_overview.html
I've seen it for around $2400 for the 21" model
NEC Multisync 2110
http://www.necmitsubishi.com/products/home/nec_index.cfm
Note that this is an analog-only monitor
I would go to www.dealtime.com or another comparison-shopping service
and put in your search parameters under Monitors and see what comes
up.  You can then do your basic research from there and then see if
you can find reviews on your favorites.
The really big, top of the line models are well over $2k.  For under
$2k, you can do very well with the slightly smaller 19"-20" models
and I think this is where the great values are today, as prices are
plummeting over where they were a year ago.
I just replaced my CRT with a Viewsonic VX900 19" digital display and
upgraded my video card to a 64 meg Radeon 9000 board.  The monitor
runs native at 1280x1024 @ 70hz.  Refresh is not the same problem on
LCDs as it is on CRTs, so you needn't insist on 85hz and above.
JT
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Dan Honemann
is
roughly
128MB
for
> the monitor.
> Dan
2003-03-05 by danhcmsinccom
John,
Thanks for your information on LCD panels.
Along with the fine brands you mention, I've also heard good things
about the Sharp monitors.  Jonathan Sacks uses a Sharp LT--T1820 and
swears by it.  Two nice features of the Sharp monitors: 10 bit gamma
correction, and independent, 6 color adjustments.
On the other hand, the Formac 2010 is very tough to beat at its
current price ($1400).  600:1 contrast ratio, .26 dot pitch (oddly,
they don't list this spec on their website: I had to hunt for it and
found it on Cnet), and fast response (10-25 ms).  Not too shabby for
a 20" LCD.
The problem point with Formac is their disreputable customer
service.  You can read some horror stories here:
http://hwreviews.netscape.com/hardware/0-2295747-418-20749942.html?
tag=subnav
... including one user who discovered a bug with the monitor using
the video card I'll have (the ATI Radeon 9700): if you shut down, you
have to unplug the Formac to get it to display on power-up.
When I called Formac's sales department, I was put on hold.  After 15
minutes, I hung up.  I phoned a few hours later and was again put on
hold, this time for 10 minutes.  I asked what the shipping charges
would be to my address, and was put on hold again--this time for 20
minutes!  When the salesman finally returned, he had forgotten what
I'd asked.
If this is what their _sales_ deparment is like, I shudder to think
of their customer support!
Dan
One last word to those interested in the subject: having researched
the 20.1" LCD monitors for the past couple of days, I've grown
convinced that several brands use a common panel: the Fujitsu
FLC51UXC8V.  This includes the Formac 2010, Viewsonic VX2000, and
even the 20" LG Electronics panel that comes bundled (as an option)
with the Gateway 700XL.  The Hitachi CML200B and Planar PL201M look
like they are also using the same technology (if not the very same
screen).
Check out the stats: they're identical for all of these monitors.
The only variable is the shell they're housed in and possibly the
control features.
Given that, and the fact that the local Gateway store says I can swap
the monitor if I'm not 100% satisfied with it, my inclination is to
go with their bundled 20" LCD for $500 less that the Formac and
Viewsonic versions (which both sell for $1400) and see if that will
work for me.
Dan
