2200 epiphany
2200 epiphany
2003-03-07 by digikdm
After numerous test prints under a variety of settings using nascent
epson software provided with the printer and no third party RIP,the
combination that I found works best for B&W prints is as follows:
1. WORK  AND PRINT in Adobe1998 color space. DO NOT use any "Epson
print space" settings( such as Epson 2200 matte MK) or you will be
rewarded with a spectrum of casts, usually magenta and /or green,
depending on other settings. Obviously , I did not try every color
space combination , but the above seems to work.
2. Always use the photorealistic color setting under the "advanced"
settings.Do not use "no color management" or you'll be rewarded with
smudged shadow areas /loss of detail.
3.For best results with minimal color shifts in various lighting, use
Matte paper and matte black ink.
With these settings I've found that my grays and blacks actually
match what I see on the monitor.I've have only dealt with B&W and
don't know if the above holds up for color prints. I am satisfied
with the prints I'm getting  now , but I wish Epson would refund all
the ink and paper I used to come to this conclusion.Their manual that
comes with the printer will send you off in the wrong direction for
B&W.Maybe this will save someone else many hours of frustration.
Re: 2200 epiphany
2003-03-07 by Peter Nelson
The workflow you describe works better than any other with
the stock Epson software, but it still produces unacceptable
levels of metamerism.
Peter Palmieri recently sent me some sample prints made
with the Epson RIP that were very impressive.  After seeing
them and comparing them with IP RIP output I can't see any
reason to spend the big bucks on the IP RIP.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "digikdm"
nascent
use
all
that
Re: [Digital BW] 2200 epiphany
2003-03-07 by Richard Sintchak
Friday, March 7, 2003, 4:53:44 AM, digikdm wrote:
d> 1. WORK  AND PRINT in Adobe1998 color space. DO NOT use any "Epson
d> print space" settings( such as Epson 2200 matte MK) or you will be
d> rewarded with a spectrum of casts, usually magenta and /or green,
d> depending on other settings. Obviously , I did not try every color
d> space combination , but the above seems to work.
Thanks for the tip. I will try this. One question: What setting do you
use under Print Space, Profile setting? Same as Source? Printer Color
Management?
Best regards,
 Richard
mailto:richard@...
L i n k s  t o  m y  g a l l e r i e s:
http://fujirangefinder.com/document.php?id=246
Re: 2200 epiphany (questions)
2003-03-07 by Robert
A couple questions for clarification:
Under Photoshop's Print Space/Profile, do you indicate "Adobe RGB"
or "Same as Source"?
Also, in your Epson settings, do you mark "Color Controls", Mode
= "Photorealistic", and leave Epson Natural Color unchecked?
Lastly, just what does "Photorealistic" really do?
Thanks
Robert Ades
nascent
use
all
that
I actually select adobe rgb in the print space because some of my
images are in grayscale rather than adobe rgb. if your image is in
adobe rgb, i'm not sure if it would matter if you selected "same as
source" or adobe rgb. it would appear to make no difference , but you
could test it.
i am working in OS 9, and i believe that the natural color box is
automatically not checked in the photorealistic mode. So for me ,
that is unchecked all the time.
as far a what photorealistic does , i'm not sure. but without it,
you will get muddy shadows. you're not talking to an expert here.
i got to this point by trial and error.
do my prints still show some unwanted tinting... yes, but it's
minimal, and i am willing to accept the situation as is for the time
being. The match-up with the mi monitor is pretty darn close. i'm
considering a RIP from epson or IP , but i'm going to wait for a
while and just keep digitallizing my backlog of images.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Robert"
> Thanks
> Robert Ades
> nascent
RIP,the
any "Epson
be
green,
color
the "advanced"
with
> use
> all
> that
for
Thanks for the reply.  It sounds like we're doing things the same way
(although I'm printing from a Windows PC).  My output does have a
noticeably blueish cast, but the shadows do seem a bit "lifted" with
the Photorealistic box checked.
-Robert
you
> could test it.
time
RGB"
> > Thanks
> > Robert Ades
> > nascent
> RIP,the
follows:
> any "Epson
> be
> green,
> color
> the "advanced"
> with
lighting,
> > use
actually
and
satisfied
refund
> > all
manual
> > that
> for
2003-03-08 by digikdm
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Sintchak
PRINT SPACE:
   PROFILE: Adobe RGB(1998)
   INTENT: relative colorimetric
BLACK POINT COMPENSATION--CHECKED
i HAVE NO IDEA WHAT BLACK POINT COMPENSATION DOES, AND I HAVE NOT
TESTED THIS SETTING INDEPENDENTLY . I ASKED  AN EPSON TECHNICAL HELP
PERSON , AND THEY SAID THEY NEVER HEARD OF IT!!!!
FINALLY, I HAVE FOUND THAT IF I SET MY MAGENTA SETTING TO (-5) IN THE
COLOR MANANGEMENT> COLOR CONTROLS> PHOTOREALISTIC MODE THAT i HAVE A
VIRTUALLY NEUTRAL B&W PRINT.GOODLUCK
any "Epson
be
green,
color
you
Color
> Management?
> Best regards,
>  Richard
> mailto:richard@c...
Re[2]: [Digital BW] 2200 epiphany
2003-03-08 by Richard Sintchak
Friday, March 7, 2003, 9:59:58 PM, digikdm wrote:
d> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Sintchak
d> PRINT SPACE:
d> \ufffd\ufffd PROFILE: Adobe RGB(1998)
d> \ufffd\ufffd INTENT: relative colorimetric
d> BLACK POINT COMPENSATION--CHECKED
d> i HAVE NO IDEA WHAT BLACK POINT COMPENSATION DOES, AND I HAVE NOT
d> TESTED THIS SETTING INDEPENDENTLY . I ASKED\ufffd AN EPSON TECHNICAL HELP
d> PERSON , AND THEY SAID THEY NEVER HEARD OF IT!!!!
d> FINALLY, I HAVE FOUND THAT IF I SET MY MAGENTA SETTING TO (-5) IN THE
COLOR MANANGEMENT>> COLOR CONTROLS> PHOTOREALISTIC MODE THAT i HAVE A
d> VIRTUALLY NEUTRAL B W PRINT.GOODLUCK
Well....thanks for the response and suggestions but I just tried it
with my XP system and it gave me the pinkest B&W results I've ever
had. Back to my 1160 and the quadtones for B&W for me.
Best regards,
 Richard
mailto:richard@...
Re[3]: [Digital BW] 2200 epiphany
Friday, March 7, 2003, 10:22:39 PM, Richard Sintchak wrote:
RS> Friday, March 7, 2003, 9:59:58 PM, digikdm wrote:
d>> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Sintchak
d>> PRINT SPACE:
d>> \ufffd\ufffd PROFILE: Adobe RGB(1998)
d>> \ufffd\ufffd INTENT: relative colorimetric
d>> BLACK POINT COMPENSATION--CHECKED
d>> i HAVE NO IDEA WHAT BLACK POINT COMPENSATION DOES, AND I HAVE NOT
d>> TESTED THIS SETTING INDEPENDENTLY . I ASKED\ufffd AN EPSON TECHNICAL HELP
d>> PERSON , AND THEY SAID THEY NEVER HEARD OF IT!!!!
d>> FINALLY, I HAVE FOUND THAT IF I SET MY MAGENTA SETTING TO (-5) IN THE
COLOR MANANGEMENT>>> COLOR CONTROLS> PHOTOREALISTIC MODE THAT i HAVE A
d>> VIRTUALLY NEUTRAL B W PRINT.GOODLUCK
RS> Well....thanks for the response and suggestions but I just tried it
RS> with my XP system and it gave me the pinkest B&W results I've ever
RS> had. Back to my 1160 and the quadtones for B&W for me.
RS> Best regards,
RS>  Richard
Whoops!  I take that back.  I had forgotten to change one setting.
Ok, once I re-checked again and printed it came out much better.
Still a slight bit of magenta in some tonal areas under tungsten light
(it's late now, I'll look at in sunlight tomorrow just to get an idea)
but is perhaps the best so far next to what I get from Lepp's EEM
profile.  The Luminous Landscape Photo-Realistic method gives me quite
a noticeable magenta cast.
Best regards,
 Richard
mailto:richard@...
