Trying to understand ink dilutions on 6-color printers
2003-03-11 by Dimitri Katsaros
I went to the MIS website to check out the ink information... the 4- ink separation makes complete sense: 25%, 50%, 75%, and 100% You just divide 100 by 4 and you get the different dilutions. However, when you go to 6-color printing, the separations are at 15%, 25%, 45%, 50%, 75%, and 100% Is this because there is a logarithmic response to how much ink you lay down in the highlights? If so, why is the 4-ink formulation using 25% for the highlights and not something a little off 25%? If the response was as linear in the 6-ink as is apparent with the 4- ink setup, you would get 16 2/3%, 33 1/3%, 50%, 66 2/3%, 83 1/3%, and 100% Please don't slam me if the answer is obvious... I'm a noob :-)
