Printer + Ink recommendations
2003-03-19 by bbiess
Help! I'm ready to take the plunge into high quality black&white printing but need some guidance. Here's what I'm considering and would really appreciate some feedback into the pros and cons of printers and inks. Since large format isn't terribly important to me at this point I am considering using either my current Epson Stylus 870 or purchasing a new Stylus 980 (they're $100 with rebate!). In either case I would dedicate the printer for B&W printing only. Am I going to see substantially better output from the 890? Do both MIS and Piezography support the 890? Where inks are concerned, I think I'm as confused as any newbie. MIS or Piezography?? I've researched both and it appears MIS is a bit cheaper to get started with and can utilize the stock Epson driver (no additional expense for the Cone driver) - however, it appears that the new Piezography system will no longer require a custom driver either. Is one easier to use than the other? What are the pros/cons of both systems? What's going to give me the most bang for the buck? I did a search on this group and wasn't able to find any kind of 'getting started' doc, but if someone knows of one I'd really appreciate the link. And any thoughts, suggestions and/or recommendations would be GREATLY appreciated!! Regards, Bob Biess
