Neutral black and white prints with the Epson 2100/2200?
2003-03-30 by martinshakeshaft
I know from the archive that this subject has been covered before but
I have still to see a definitive answer.
Is it possible to get neutral black and white prints with the Epson
2100/2200?
Well here I am one box of paper down and I have still to see a black
and white print that I like!
Straight out of the box I find the black and white prints I am
getting are too magenta, especially with the Semi gloss paper samples
included with the printer. So I tried Ilford Smooth Gloss. These were
a bit better but still not what I wanted. I have surfed around the
net for advice, including Redriver and luminous-landscape and whilst
the quality improves when I hold my prints next to a traditional
darkroom print the differences are all too depressingly obvious.
There are colour casts in some tonal ranges.....
So I turned to the Grey Balancer. Several prints later and a lot less
ink and I still don't appear to be any further on towards a totally
neutral, Ilford Multigrade looking print.
Even prints printed with black ink only are not neutral, they look
slightly cyan in the darker tonal ranges.
I phoned Lyson Inks who say a Black and white set of inks will be
available in the next couple of weeks for the 2100/2200, so is this
my only answer? I am disappointed if this is the route I have to take
as I did want to be able to print colour and black and white, but
black and white is my bread and butter work at the moment.
Any help would be appreciated.
Martin
Re: Neutral black and white prints with the Epson 2100/2200?
2003-03-30 by Antonis Ricos
Martin,
if you use a Mac OS 8 or 9, you may want to try the free OPM software we've
been discussing, as well as the Ultratone inks fom MIS.
Take a look at the messages of the last few days....
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "martinshakeshaft"
> Martin
Antonis
Thanks for the suggestion but I am running Win 2000.
Cheers
Martin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonis Ricos"
<antonisphoto@y...> wrote:
> Martin,
software we've
2003-03-30 by Johnny Eades
Hello Martin,
I have seen the responses to your question and none of them seem to
mention maybe a change of inks. I haven't had an Epson printer but
one week and am very impressed with it. I don't have the 2200, but
rather the old 1280. I had a Canon s750 for my black and white
printing and almost went bananas trying to get a neutral black and
white print from it. I discovered, via Clayton Jones website and
messages to this newsgroup, a method called "Black Only" printing
that uses only the black ink cartridge. With the Canon printer the
only way to use black only was to choose plain paper for printing.
The Epson will let me choose black only for any paper type. Even
this method does not yield a neutral black and white, but the
slightly brown tone due to the carbon color itself. Now back to
neutral color black and white printing, I use MIS Variable Mix ink
cartridges and a printing curve by Paul Roark; which is also
available from the MIS website www.inksupply.com. I use either
Office Depot Presentation Paper (Matte) or Epson Enhanced Matte
Paper. Both papers give neutral prints with the inkset mentioned
above. Bulk ink is available for refilling the cartrdges. Look
around on different newsgroups and I think you will find MIS
mentioned often. Another avenue to take is Jon Cone's PiezographyBW
software and ink combination coming on sale about the first week of
April. It will support Epson and Canon printers . The releases will
be staggered for different printers and not all will be supported at
the first release. Check on that website also www.piezography.com.
The software appears to let you do everything from within Photoshop
itself and export it to the printer via the Piezography software
and/or plugin.
Your friend in Photography
Johnny Eades
--- In
but
> 2100/2200?
black
samples
were
whilst
less
totally
this
take
> Martin
2003-03-31 by Peter Nelson
--- In
but
If you checked the archives you should know that several
RIPs will give you decent results without having to resort
to 3rd-party inks.
Also the big problem with the 2200 is NOT static color
casts, but metamerism!  In other words, it's not a question
of it being too magenta or too green, but rather, being magenta
under one kind of light andf green under another one.
See my website for a discussion of this:
http://studio-nelson.com/inkjet/bw22001.htm
