OPM
OPM
2003-03-31 by jnhugo
sorry if this is obvious to everyone---but, downloaded the OPM and
found that it is sharper and finer than the piezo plug. I am using
g3/500 9.2.2, 1280, MIS FS.
The files that print pretty well with PZO print light on OPM. I
reprinted 21 step with opm, changed my dot gain to match, readjusted
the picture files and I think they print kind of muddy---. What is
the work flow with OPM? Do I need to do anything to the EPSON profile
box or does OPM set the parameters of the printer? What about monitor
proofing? Use the same settings as PZO or what? In other words: what
is the "normal" workflow with this OPM-thanks, Jack
Re: OPM workflow vs older workflows
2003-03-31 by Antonis Ricos
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jnhugo"
Jack,
I am not surprised about that: profiles made with IJC tend to have open
shadows in general and that makes them look lighter. On top of that, who
knows what the profiles for the piezo plug in are doing for you now.
Not only were they made ages ago, they weren't even meant  for the FS inks. I
couldn't even get my own 1280 to work with the Selenium tones which
allegedly work with the profiles that  Inkjet Mall sold as part of the plug in.
They told me to try all their profiles until one worked! That is why I have
abandoned using canned profiles of any sort.
That muddiness would probably be the result of a mismatch between how the
profiles for OPM work and however you compensate in the print.  Be careful
with gamma settings: If you had been working in gamma 2.2 and sent one of
those files to OPM - which defaults to 1.8 - you would get a way-light print. By
adjusting your file to compensate then, you probably end up with an
unintended "left turn". Check your gamma settings before you make custom
dot gain curves etc, and see how they compare.
Generally, you want the least deviation between your scan and your print
(other than local corrections). So, as a test, here is how you would proceed:
- make a scan that looks good in - for example - gamma 1.8
- open it in photoshop under gamma 1.8 (in the gray settings). It should look
fine, except for local corrections.
- if you print it with OPM at this point, make sure OPM is set to 1.8
- let the print dry for at least an hour (if not a day, for maximum accuracy with
FS inks). You can use a hair dryer but don't scorch the print.
- At this point, your print should match the monitor closely, but will look lighter
in the shadows. Now, make a custom dot gain to match the two, but don't  load
it as your gray space in Photoshop. Save it as a gray profile and load it as a
soft proof.
-Now you can switch back and forth between soft proof preview and the
straight 1.8 gamma (loaded as gray space in PS) and you will see how
different 1.8 is from your print. Make any final tweaks to your file under this
preview and reprint. You should now have made the least possible
adjustments to your file - only the small difference between the abstract
gamma 1.8 as defined in photoshop and the dot gain curve you made to
compensate for the specific print.
Besides the above workflow example, keep in mind the following:
-  If you have IJC and you need to print "legacy" files, i.e. files you liked under
an older workflow - such as the plug in, or RGB workflows, or Image Print or
anything else - and don't want to be readjusting the files, you can make a
profile to match the densities of the old workflow, and thus not risk breaking
the histogram in those files - or do a lot of extra work.
- In a pinch, if you find your files print too light or too dark, or need more or less
contrast, you are far better off trying the contrast / exposure adjustments in
OPM than adjusting the files themselves under an "eyeballed" custom gamma
curve. But because, unlike a profile, those settings are not saved in OPM, you
have to write them down and reapply them every time you launch OPM.
OPM completely bypasses the Epson driver. Use the Epson driver only to
access the printer utility. No other settings have any effect with OPM.
Antonis
OPM
2003-07-17 by jean verrept
Ave All.
When I choose in my Epson 2100 the 2200 IJC-profiles made by Antonis Ricos,
(free OPM software)  I get the message 'Selected printer is not supported
yet'. Is the Epson 2200 (US) not the same as the 2100(Europe) in this
respect? Am I hitting the wrong keys? Do I have to wait for new/revised
profiles or do I have to buy the software bundle  instead?
I told  the BowHaus people about the 2200/2100  printer dilemma but have not
received a reply so far, hence my question to the group.
Thanks in advance for your assistance.
Jean
