Clarification needed please
2003-04-08 by mcgillicuddytcb
Hi all,
Hope this post finds you all well. I realise I may be being simple
here but would appreciate somebody pointing out the obviouse to me
please.
Reading Jon Cones latest mail on the list have I interpreted the
info correctly, is he saying that the inks in a six colour printer
are the same as a quad?? ie with say the "M" and "m" positions
containing ink of an identical tone or density??? If this is what he
means is that true of all ink sets? Are hex tones really quads in
disguise???
Clarification appreciated.
Damian
Re: Clarification needed please
2003-04-08 by Johnny Eades
Hello Mr. Mcgillicuddy
I think most hextone inks have a Light Magenta and a Light Cyan with
the Cyan Magenta Yellow and Black positions. They are actually gray
inks that have the same density as the colored inkset.
Your friend in Photography
Johnny Eades
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "mcgillicuddytcb"
<mcgillicuddy@0...> wrote:
> Hi all,
> please.
he
> disguise???
> Damian
Re: Clarification needed: 6-ink vs 4-ink sets
2003-04-08 by Antonis Ricos
> disguise???
 Damian,
in a word.... yes!  It all started back in the days of the old piezo plug in and
piezo pro, then the approach was transferred over to ImagePrint. The old
piezo inks and all current Piezotone inksets, as well as those of the MIS inks
that claim to be compatible with the piezo software, use the exact same ink
between Magenta and Photo Magenta and between Cyan and Photo Cyan.
You could interpret this as missing out on the benefits of a true hex tone set -
or, if you look closely, realize that the problem is not so much with using 6 vs 4
shades of gray:  3 grays and a black will give you a fine grayscale, especially
with newer printers like the 1280 and 2200 (assuming UT inks).  Most people
are happy with the old 1160 and its quad scale.
The reason for using the extra 2 inks to better advantage is twofold:
(a) you can use them as "toners" to cool or warm the overall print color
or
(b) you can use them with careful 6-color profiling to reduce the appearance
of dots in older machines that tend to put down a bigger "device dot" .
Both of these options are not possible with older software like the piezo
plug-in, or ImagePrint. They are designed to produce a  4-ink scale. In fact, IP
has an internal function of randomly using one or the other of the pairs (C/PC
and M/PM) in an attempt to even out their use. But if one of your heads has a
clog and the other doesn't , you'll go mad trying to chase it down !
Newer softwar like IJC addresses both issues, as would any 6- or 7-color true
CcMmYK RIP.
The other problem with the current 4-ink or "fake 6-ink" sets, is that the density
differences between inks is less than ideal. The Cyan position is very close to
black, for example. Or, in the case of the 2200, 2 grays and a black might  be
enough because the dots are so fine. Eventually we should get to a place
where new inksets will be available with  better distribution of densities from
lightest gray to black.
Antonis
