> Hello Diana;
> I tried to restore this thread under its original subject heading and so repeated
> our previous messages below for anyone who wants to follow this. It's easy to
> hit reply and end up with "Digest" as your subject!....
> I am glad you saw an improvement in your results with the resing-up tip. There
> is continuing development on OPM, with a beta version currently being
> tested for the 2200 (no new features, just tweaks to address some of the
> issues users have reported). Should you buy IJC, you will find that it is
> capable of controlling up to 7 ink channels with smooth spline curves that
> can accept 20+ points each (normally 2 or 3 are plenty). That gives
> unprecedented controll over the amount and combination of inks to be laid
> down for each digital value in your image file. As has been discussed here
> before, for the full benefit you would need a densitometer, but good results
> are also possible by visually comparing your output to a good print of the
> 26-step grayscale.
> A note about comparing printing software: Comparisons between OPM and
> any other bw printer driver would generally have to assume perfect profiles
> for each, so that the drivers are in fact compared, not the profiles. This gets
> tricky if drivers that rely on canned profiles are fixed to a certain performance,
> while OPM uses custom profiles (made in IJC) that can take into account
> every nuance of your particular set up. This is less of an issue with printers
> like the 2200 using OEM carts, and a bigger problem with CIS-equipped
> desktops and large formats.
> I hope you can let us know what you think of the results your are getting.
> Antonis
> Hi Antonis,
> I took your advice about rezzing up a file to 720 dpi and changing to
> 16 bits and I got MUCH better results with OPM, at least for 1
> particular image with lots of thin strong diagonals. There had been
> noticeable (but fine) stairsteps when the file was 300 dpi and 8
> bits. The same file printed with Roy's QuadToneRIP under OSX didn't
> have the stairstep problems though - maybe his driver can rez up the
> file like the Epson driver.
> I think both programs/drivers have alot of potential. I haven't
> purchased Inkjet Control (yet) but the fact that their software lets
> you tweak every ink channel is very nice. With QuadToneRip, you tweak
> 4 channels in CMYK mode, regardless of printer model (at least that
> is the case for the 2200 curves). At least with both programs I'm
> seeing no metamerism with the Matte Black ink on EAM and Eclipse
> Satine, whereas the Epson driver always gives me greens and/or
> magentas!
> By the way, I have a Mac G4 and am running OPM under OS 9.1. I run
> Roy's QuadToneRIP under OSX 10.4.2.
> Diana
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonis Ricos"
> <antonisphoto@y...> wrote:
> > Diana,
> > I have discovered that some images look sharpest at 720 dpi when printed
> > with OPM on the 2200. If you open your image in Photoshop and check the
> > resolution it should read 720 dpi. If not, you can res it up using bicubic
> > interpolation. Then try printing again.
> > This may or may not make a big difference in your print depending on how
> > close you were to 720 dpi before you resed up. It also depends on what
> kind
> > of image it is - how grainy, how sharp, if it has sharp diagonals... etc.
> > Also, if you still see problems, it's worth setting the image to 16 bits and
> > comparing prints.
> > Testing tip:you can crop a small area where a problem shows up and print it
> > over and over on the same sheet with different settings. You set the x,y
> > positions in OPM to avoid overlaps.
> > Just to be clear about the 720dpi "preference": It is unrelated to the amount
> of
> > information a scan or digital camera file contains; it has to do with matching
> > pixels-to-dots and driving the printer at its native hardware resolution. The
> > Epson driver (for the 2200 at least) does this interpolation internally, so no
> > matter what res you throw at it, the image will be made to look its "best" as
> far
> > as the printer goes.
> > I am very interested in your comparisons between Roy's RIP and OPM -
> > especially since they share some DNA between them ! (and didn't that
> > originate at MIT?....) The tonal gradations in OPM are mostly the result of a
> > particular profile and whether your particular system performs as well as
> mine
> > (since I made the first 2200 profiles).
> > In theory, you are supposed to have IJC and be able to tweak the profiles
> > both for color and for smoothness. This system is really aimed at putting an
> > end to canned profiles of any kind (including its own) !
> > As we discuss this further, it would help if you mentioned your operating
> > system and other details of your setup.
> > If you are experiencing problems with the 2200, you may want to write to
> > bowhaus and see if they will let you try the current beta which has some
> fixes
> > for the 2200. Their email for OPM / IJC is: software@b...
> > Antonis
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Diana Park
> > <dip@m...> wrote:
> > > Antonis,
> > > I've just started experimenting with OPM on my 2200 and I'm not sure
> > > what you meant below - should the file actually be set to 720 dpi or
> > > should the printer output be set to 720 (as opposed to 1440 or 2880)?
> > > I haven't purchased IJC so I can't control the curves supplied with
> > > OPM but I do like the Blender option where I can mix warm and cool
> > > curves. I've found 70% warm and 30% cool to give a nice neutral (to
> > > my eye) tone.
> > > I've also FINALLY successfully installed Roy Harrington's QuadToneRIP
> > > (many thanks Roy for all your troubleshooting help!) and while his
> > > neutral curve is warmer than the above mix in OPM, the tonal
> > > gradations seem smoother. Now for some curve tweaking!
> > > Diana Park
> > > dip@M...
