Printing B&W photos with an Epson 1270
2003-04-22 by hierrolopes
Can someone please tell me what are the best inks, papers or
duotones for obtaining B&W photos that look the most similar
possible as traditional lab B&W photos, and without green or other
color casts? And is it better printing with the color ink option or
just the Black ink option?
Thankyou
Re: Printing B&W photos with an Epson 1270
2003-04-24 by dsmithhfx
I've been printing b&w, as well as color on a 1270 for about 3 months
on a couple of different papers, Epson Heavy Weight Matte and Ilford
Classic Pearl. Because I only have the one printer, and want to
continue to be able to print color, I have not tried hextone inks.
The inks I have tried are Epson oem, and MIS "Epson equivalent"
dyebased inks, to refill the oem T007 (black) and T009 (5-color)
cartridges.
The MIS ink is a very close, but not quite perfect match of the oem
ink. This doesn't really matter, as very slight adjustments in work
flow render them identical for all purposes. Neither is archival, in
fact I was getting a pronounced greenish --> brown color shift in
black only prints within a few weeks, until I got some sleeves to
protect them from direct air contact (the shift was not so noticeable
in monochrome full color and 'real' full color prints).
The degree to which a given print might begin to resemble
a 'traditional lab b & w photo' seems very dependent upon the
particular negative and its tonal ranges. A black only print from the
1270 is, in my limited experience, less likely to resemble
the 'traditional' look. A monochrome print using all colors can be
made to look more like a traditional b & w print, again depending on
the negative. I just want to stress that, for me, some negatives work
better printed black only, and others as [grey] monochromes using
full color.
The two papers are wildly different in output, as you might expect.
The Ilford Classic Pearl has a sheen similar to 'traditional' RC
semimatte paper -- until you lay down ink on it. The ink is absorbed
to an extent by the coating (I've heard it described as a 'gel') but
the ink definitely sits on top and coats it, unevenly. It also
doesn't dry as well or quickly, and seems subject to 'bronzing' even
when sleeved. It looks nothing whatsoever like exposed and developed
silver emulsion (in fact it looks more like a commercial litho print
on some weird plasticized stock). In short, after printing it doesn't
look any more like 'traditional' prints than the HWM; it is just
different in a diferent way (it is also considerably more expensive).
The good news is that a lot of these differences seem to disappear as
soon as the prints are framed under glass. Then it becomes more
difficult to discern differences from traditional prints, unless you
view them from an extreme angle as to be able to plainly see light
reflected from the print surface. The other good news is that large
digital prints seem to hold detail better, without visible grain that
you would see in equivalent enlarger prints. 12 x 18" digital prints
made from scanned, 35mm slides and negs can look as sharp to the
naked eye as 'traditional', hand-printed 8 x10's -- and way better
than lab prints. And my scanners are kind of crappy (an old Polaroid
2000ppi slide scanner, and a new Epson 1660 3200x1600ppi flatbed
photoscanner).
I'm sure someone with a lot more experience in digital printing than
I, and with a more heterogenous and 'controlled' negative library
could probably obtain more consistent results. I have several years
of experience developing and printing b & w negatives by the
traditional method using chemicals in trays, so I know what such
prints look like.
From what I've read in here (and elsewhere), the 1270 may not be the
best printer for digital b & w, if you are aiming for highest print
quality, and archival prints using pigment-base inks.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "hierrolopes"
> Thankyou
