Re: [Digital BW] Re: Sprintscan120/Silverfast6 & Glass holder sharpness problem
2003-05-03 by Martin Wesley
Frank, You can open the raw tif file directly in PS. This is a workflow many have favored for B&W work. The only draw back is that in raw files the data is often very bunched up in one area of the histogram, frequently at one end. This can be very difficult to work with in PS. Whether you make adjustments in the scanning software or PS, it is important to set you histogram endpoints as the first and only adjustment. This will spread the data out over the 16-bit range without loss. For instance do a gamma change before or at the same time as setting the endpoints can result in a small loss of data or combing that will show up as you do additional adjustments. I am raw scanning with SF, opening the file with SF HDR and loosely setting my levels endpoints only and then sending the file into PS for all further adjustment. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: "frankg_photo" <fh.gross@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Saturday, May 03, 2003 12:40 PM Subject: [Digital BW] Re: Sprintscan120/Silverfast6 & Glass holder sharpness problem > > > > Yes. In Insight you choose to scan to file and it opens a window > that let's > > you choose the file type. One of the choices is 16-bit raw tif. > > Is there any reason not to simply open this file in Photoshop (saved > in Insight as a RAW Tif 16 bit)? > If PS cant they now have a plugin called Camera RAW Jpeg 2000. > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot; > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
