Re: [Digital BW] Sprintscan120/Silverfast6 & Glass holder sharpness problem
2003-05-03 by Martin Wesley
Sent: Friday, May 02, 2003 8:20 PM
Subject: [Digital BW] Sprintscan120/Silverfast6 & Glass holder sharpness
problem
> Martin,
> Thanks for this - all good points.
> My issue with SF is that film in the glass holder will not be
> focused - although the focus icon is "on" in the SF interface it does
> not actually focus the hardware (on the film plane) !
Frank,
Keep bugging SF techsupport and perhaps bug Polaroid too. If they are
bundling SF with the scanner they have an obligation too.
> Maybe someone else with the Sprintscan, Silverfast and the Glass
> Holder can jump in here and tell what their focus experience has
> been ?
I didn't use the scanner much with the glass holder as I got the holder
about the same time I got the Howtek. I don't recall any focus problems.
> Since trying Insight I have had better focus - but there are 2 things
> that I miss already compared to SF:
> 1. the Histogram with the little sliders to bring the scan into the
> high & low range.
There is a simple Levels/Histogram tool with sliders. Getting to it is not
obvious and unfortunately I no longer have the software installed to tell
you how to open it but it is there.
> 2. For the occasional col transparency there is no 'calibration' like
> the IT8 supplied with SF
If you do a raw scan with Insight I believe you should be able to apply
calibration when you open the tiff file with SF HDR, but color is not my
strong point.
> To clarify your workflow described below; you choose the 16 bit Raw
> scan option in Insight, save it as a Tif. Then open SF HDR and import
> it. Make global adjustments, then export to PS. ?
Yes. In Insight you choose to scan to file and it opens a window that let's
you choose the file type. One of the choices is 16-bit raw tif. When you
open the file with SF HDR you have all the same tools you have in regular
SF. Remember that SF is just manipulating the data stream from the scanner.
The only difference between using SF directly and the RAW-to-SF HDR method
is that SF is doing the adjustments on the fly.
Leaving the glass holder out of the workflow for the moment, try scanning in
SF and make a note of your settings. Do a raw scan in Insight and open it
with SF HDR using the same settings you used with SF and see how the results
compare.
Martin
> DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Wesley"
> <mwesley250@e...> wrote:
> > Frank,
> > I've used the Sprintscan 120 and SF before I got my Howtek. I would
> not have
> > bothered to move up to the Howtek except I needed a way to get top
> quality
> > scans of 4x5 negs. I would have to give the Howtek the edge in
> sharpness at
> > the scan level but, as Antonis pointed out, it is the print
> sharpness that
> > really matters and the difference is minor. I think you would be
> hard
> > pressed to look at two prints and say one was from a Howtek scan
> and one was
> > from a SS120 scan.
> > A year or more back Tim Spragens and I compared the output of the
> SS120 and
> > the equivalent Minolta unit. The scans were not precisely the same
> but we
> > concluded there was no difference in quality.
> > Silverfast has often been a pain though. When the scanner came out,
> there
> > was a bug involving SF, Window 2000 and Firewire connections. For a
> > considerable time I did raw scans using Polaroid Insight. I then
> opened the
> > raw file either with the Silverfast HDR module, which you should
> have, or
> > directly into Photoshop.
> > This is a very good workflow and essentially how I use SF with my
> Howtek. I
> > do a raw scan to a TIFF file and then "scan" the data using SF HDR
> making
> > first overall adjustments and outputting a 16-bit file to PS. The
> has the
> > advantage of being able to make different corrected "scans" very
> quickly.
> > The other thing to watch with Silverfast is that they will get
> around to
> > fixing the problem. (I actually thought they had corrected this
> particular
> > one.) They also occasionally lose fixes when releasing upgrades.
> The trick
> > is to check their site often and stay on top of the often frequent
> upgrades
> > and save all the versions. In the meantime just use Insight. As far
> as I can
> > tell it's a fine okay program for B&W work.
> > I also do all my sharpening in PS and not during scanning since I
> find the
> > amount needed is print size dependent.
> > Martin Wesley
> > http://www.borderless-photos.de/guests.html
> > From: "frankg_photo" <fh.gross@s...>
> > Sent: Friday, May 02, 2003 2:10 PM
> > Subject: [Digital BW] Re: Sprintscan120/Silverfast6 (& Glass
> holder) scan
> > sharpness problem
> > > Thank you for the offer to test scan a couple of frames - maybe
> I'll
> > > take you up on this.
> > > Yes I have been in email contact with SF tech support all day - it
> > > seems that the Focus button which you refer to that greys out or
> is
> > > col (off/on) is not effective with the glass holder!
> > > In other words there is effectively no scanner focusing when the
> > > glass carrier is used. It is just focused on wherever the
> > > default/manual setting is - which is pretty close but probably the
> > > thickness of the glass away from being optimum.
> > > Try a few transparencies or negs in this usual mode and then try
> them
> > > with Polaroid Insight (f you have it installed - if not it's free
> > > from the polaroid>support>download site) - you may be very
> surprised
> > > at what you thought was in focus. I was - suddenly there is detail
> > > and texture that i never saw before !
> > > Frank
> > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh
> Jani"
> > > <shilesh.jani@s...> wrote:
> > > > Yes it is.  Have you confirmed this with people at Silverfast? I
> > > know
> > > > SF 6 cannot manually focus the SS120.  But there is a tab for
> this
> > > > function - must be in all versions of SF.  It toggles between
> being
> > > > grayed out and showing an "A".  I have assumed that "A" stands
> for
> > > > autofocus - hey how about the SF documentation, eh ;-(.
> > > > Quite frankly, I have not encountered "soft" scans when scanning
> > > > transparencies (which is mostly what I use).  But, I am going to
> > > > explore this further.  For me, at least, it may be a lesser
> problem
> > > > because I don't scan too many negatives, and in fact have
> recently
> > > > decided NEVER to shoot them any more.  I like the grain I get
> from
> > > > Fujichrome Provia 400 when pushed 1 or 2 stops.  And, it is so
> much
> > > > easier to scan than Tri-X or Ilford Delta 3200.  I like some
> > > features
> > > > of SF 6, but I can live without them.
> > > > Is it possible that the problem is in your scanner?  If you
> like, I
> > > > would gladly scan a couple of your negatives  to test it out.
> > > > Contact me off-list.
> > > > If all esle fails, time to be rid of the scanner, and go with a
> > > > Minolta or Nikon (argh  $$$$).
> > > > Regards.
> > > > Shilesh
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
2003-05-03 by Ernst Dinkla
Sent: Saturday, May 03, 2003 5:20 AM
sharpness problem
> Martin,
it does
Glass
has
> been ?
things
> high & low range.
'calibration' like
Raw
import
> Frank
Frank,
I guess Vuescan will support the Polaroid Sprintscan. You could
try the demo to check the focussing in that program.
Most of what Silverfast does is in that program too and with less
hassle in my opinion.
IT8 calibration available and you can use the IT8 target of
Silverfast (which is probably a Wolf Faust IT8).
Using it with a Nikon 8000 + Epson 3200 with glass holders and
wet mounting etc.
Pricing has been changed but still a lot cheaper than Silverfast.
Supports almost all the scanners available in just one license,
license covers 4 OSses, and the user is allowed to use it on 4
systems. Sounds a lot better than the Silverfast deal. But you
got that one already .....
www.hamrick.com
Ernst
2003-05-03 by frankg_photo
Martin,
I'll try out the workflow you suggest experimenting with.
SF will no longer develop for Polaroid because ogf the
discontinuation of the scanner - and also there is some issue on
olaroids part about not changing anything since they got into
financial difficulty
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Wesley"
sharpness
> problem
> > Martin,
does
> Frank,
are
> > been ?
holder
problems.
things
> > high & low range.
is not
to tell
like
apply
not my
> strong point.
Raw
import
that let's
When you
regular
scanner.
method
scanning in
open it
the results
> compare.
> Martin
> > > Frank,
would
> > not have
top
> > quality
> > sharpness at
> > sharpness that
> > hard
> > and one was
> > > from a SS120 scan.
> > SS120 and
same
> > but we
out,
> > there
For a
> > opened the
> > have, or
my
> > Howtek. I
HDR
> > making
The
> > has the
> > quickly.
> > around to
> > particular
> > The trick
frequent
> > upgrades
far
> > as I can
I
> > find the
> > > Martin Wesley
> > holder) scan
> > > sharpness problem
maybe
> > I'll
day - it
or
> > is
probably the
try
> > them
free
> > surprised
detail
> > > > Frank
> > Jani"
Silverfast? I
> > > > know
for
> > this
between
> > being
stands
> > for
scanning
going to
> > problem
> > recently
get
> > from
so
> > much
> > > > features
> > like, I
out.
with a
> > > > > Regards.
> > > > > Shilesh
Polls and
wish to
this same
> page.
messages to keep
> them short.
header.
various
2003-05-03 by Shilesh Jani
Martin & Frank
Thank you for the good ideas.  I tried using Insight (for the first
time), and sure enough the sharpness was a tab bit better, not by
much though.  I was scanning 6 x 9 slides at 4000 dpi, and down
sampling the file for a 360 dpi, 12 x 18 print, at which point the
minor sharpness difference was no longer discernible.  But now, I
actually like Insight:-)  It is faster, and I don't get the
occasional banding I was seeing in SF.
To use the histogram in Insight:  First you must NOT have a profile
tagged to the scan.  You do this in "user preferences" in the "scan"
tab.  After you prescan, open the curves tab, and hit the histogram
button.  You will now have the black/white/mid point contols.
Regards.
Shilesh
sharpness
> problem
> > Martin,
does
> Frank,
are
> > been ?
holder
problems.
things
> > high & low range.
is not
to tell
like
apply
not my
> strong point.
Raw
import
that let's
When you
regular
scanner.
method
scanning in
open it
the results
> compare.
> Martin
> > > Frank,
would
> > not have
top
> > quality
> > sharpness at
> > sharpness that
> > hard
> > and one was
> > > from a SS120 scan.
> > SS120 and
same
> > but we
out,
> > there
For a
> > opened the
> > have, or
my
> > Howtek. I
HDR
> > making
The
> > has the
> > quickly.
> > around to
> > particular
> > The trick
frequent
> > upgrades
far
> > as I can
I
> > find the
> > > Martin Wesley
> > holder) scan
> > > sharpness problem
maybe
> > I'll
day - it
or
> > is
probably the
try
> > them
free
> > surprised
detail
> > > > Frank
> > Jani"
Silverfast? I
> > > > know
for
> > this
between
> > being
stands
> > for
scanning
going to
> > problem
> > recently
get
> > from
so
> > much
> > > > features
> > like, I
out.
with a
> > > > > Regards.
> > > > > Shilesh
Polls and
wish to
this same
> page.
messages to keep
> them short.
header.
various
Re: Sprintscan120/Silverfast6 & Glass holder sharpness problem
that let's
Is there any reason not to simply open this file in Photoshop (saved
in Insight as a RAW Tif 16 bit)?
If PS cant they now have a plugin called Camera RAW Jpeg 2000.
