Web design consideration
2003-05-14 by Lyons Cox
Curious about those of you who have designed web pages.
Some folks have popup killers to keep 'ads' from popping up.
Does this get in the way of those web pages that pop up a new window when hitting a link.
A question from the naive, who has neither.
Cleavis
Re: Web design consideration
2003-05-14 by Duncan Staples
Cleavis:
I have not found there to be a problem.  Most smart browsers and
popup killing software is designed to look for scripts that are self
activating.  If you create a web page that generates a popup from a
link you should not have a problem.  You will have a problem if you
are generating links via a timed script etc.  Be careful how you use
popup windows as they rank fairly low on usability tests.
Duncan Staples
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lyons Cox"
> Cleavis
