Color to BW, was Digital, film, scanning comparisons
2003-05-22 by grdglass@aol.com
This is interesting because I have never been able to make a B+W print from a
color digital capture that had the look of a print from B+W film.  I believe
I have tried every method and every plugin and the print never looks "real."
Converting color to B+W in Photoshop doesn't work, IMO.
Helene
> >"Simulate" is the operative word here.  You can make something
> >look like Tri-X or Tech Pan, but if you compare it with the
> >same scene actually photographed with these films, you may be
> >surprised.  Almost all the information required to reproduce the
> >response of most B&W films is missing from color images.
> >You can certainly produce fine prints; but if you want prints
> >that look exactly the way a certain film looks, you must
> >capture the original scene with that film.
> I've been following this thread with great interest.  It's a subject
> that has concerned me for a long time, as I've hinted at in past posts
> about my fear of losing the look and feel of particular films.  You
> have finally brought to the table a credible explanation for what I
> have only suspected.
> I don't have a high end digi cam, but do have a 4mpx model with a
> decent lens, and so have been able to try making BW prints from a
> few images.  I even tried using the demo version of the software that
> emulates different films, and it's quite good.  The few images I
> worked up were sharp, well rendered, and made prints that were
> basically "good" in many ways, yet failed to fully satisfy by not
> "pressing my button" in the way my scans of Tri-X negs have.
> I'm not giving up hope for an all-digital workflow.  Perhaps better
> cameras, software, and my own improving skills will make it possible
> someday.  In the meantime I'll save my shekels and shoot film.  6x7
> Tri-X negs made with Pentax 67 lenses are hard to beat.
Re: Color to BW, was Digital, film, scanning comparisons
2003-05-22 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, grdglass@a...
print from a
I believe
looks "real."
Let's not get all mystical about it.   The response curves for all
their films are available from Kodak.  A response curve is a vector
of scalars.  It should be simple linear algebra to take two response
curves and come up with a third curve that represents the conversion
of one to the other.   The only case that would fail is if the
target response curve had a wider latitude than the source one.  So
if you start with a wide latitude color film why should it be hard
to simulate a b+w film of similar or narrower latitude?
