MIS Ultracrome Inks -Solarization on Glossy
2003-05-23 by birdbrainpress
Thank you Paul for the previous posting regarding the solarization
problem I am having using MIS Ultrachrome on Glossy (using Epson
1270).
I believe you suggested I work on adjusting the curves. I am curious
what is the cause of the solarization and where I might start in
approaching adjustments of the curves.
Thank You
Eric Brotman
RE: [Digital BW] MIS Ultra Tone Inks -Solarization on Glossy
2003-05-23 by Paul Roark
Eric,
>... regarding the solarization ... using MIS Ultrachrome on Glossy ...
I assume you are using the MIS Ultra Tone B&W inkset, not the Epson color
UltraChrome inkset or the MIS clone of it.
>using Epson 1270
There are older curves that are for the PC and another set for the Mac.
There is also a newer set for both that uses the No Color Adjustment
setting.  So, for either computer there are 2 full sets of curves for the
1270.  The first thing to do would be to try the curves and see if one set
is better than the other.
Both sets were written for Epson Enhanced/Archival Matte paper, however.  So
if the paper is the cause of the problem -- which is likely -- the results
may not be much different.
I'm not 100% sure what you mean by "solarization."  It might be a flat spot
in the grayscale curve, or some might see the "bronzing" and describe it as
this effect.  Both are defects that may be problematic with RC papers.  The
bronzing seems to be something that sprays might fix, and some papers have
very little.
As to the grayscale ramp flat spots, most papers absorb the inks slightly
differently.  Most matte papers are close enough that the "canned" curves
work OK with a number of different matte papers.  The RC/glossy papers, are,
no doubt, more divergent from the matte papers in their characteristics.  I
was surprised the existing curves worked as well as they did on the RC
papers I tested.  The warm curves were the only ones I saw serious flat
spots on.
One thing that appears to explain some of the problems is that the RC papers
may not be able to handle as much ink as the matte papers.  One 1160 Ultra
Tone (UT) user found that the new curves I wrote for the 1160 curved the
problems he was having.  The difference in the curves that might account for
the improvement is that I pulled the light gray curve back up after the dark
gray (cyan) started to take over the image-forming work.  This probably
reduced the total amount of ink on the paper.
So, one thing I would consider in re-writing the 1270 (or any) curves is to
pull that light ink out of there as soon as possible.  Rely on the cyan ink
for the midtone and all but deep shadows.
By pulling the light gray back up you can also hold the black ink back until
the very deepest shadows.  With the Eboni ink, I've found this really
improves shadow smoothness.  I have not done enough work with RC paper to
know the effect on them.  Frankly, I'm not sure there is an RC paper I'm
interested in enough to write curves for at this point.  If there is a
clearly superior one, I'll buy some and see what works with it.
I hope this gives you some help in fighting the problem.
http://www.PaulRoark.com
Re: MIS Ultracrome Inks -Solarization on Glossy
2003-05-24 by akreskin
Eric,
For what it's worth.  Have you tried the "Epson Photo Paper".  In my
case it was the only paper I was able to get exceptable results with
using the existing curves and UltraTone B&W Inks. Anything glossier
got the same results you got. I had high hopes for the Pictorico
Photo Gallery Gloss but the results were unexceptable(Bronzing,etc.)
I like the tone of the inks very much(Paul's NC Curve) but I've
switched back to using them on matte only (with the FSN Black). I
tried an experiment and printed them with Cones driver on the
Pictorico Paper and much of the Bronzing was eliminated, but of
course I couldn't control the tones. I'm not capapable of writing
curves so I'm going to stick with the Matte until someone smarter
then myself comes up with some curves that work with the 1200. Paul,
thanks for all your hard work, the inks are beautiful when printed
on Matte paper.
Scotty
Scotty
DigitalBlackandWhiteThePrint@yahoogroups.com, "birdbrainpress"
> 1270).
curious
> Thank You
> Eric Brotman
