Subject: Re: Digital, film, scanning comparisons
2003-06-08 by HPA
You can try using a sheet of glass over the neg to lock it flat.  Problem
with my scanner is that the heat of the trannie bulb causes miniscule
movement of trannie resulting in unsharpness.  Big difference with extra
glass.  If it works for you on a trial basis, and you have newton ring
problmes, just get a anti-newton ring glass.
tom robinson
> that any drum scan would produce better quality than my flatbed, but the
> Epson 1680 seems to do pretty well for LF work. I'm actually toying with the
> idea of getting some Kami fluid, or equivalent, and trying a quasi wet-mount
> directly on the glass. I've read some things about the 'net of people using
> mineral oil, etc., and reporting higher resolution scans with better shadow
> detail. All good things! But, then there's the cleanup. <G>
