Re:levels and grain
2003-06-10 by grdglass@aol.com
Stephen, Nice technique. Where exactly does the the box pop up asking about medium gray...in the background copy layer? I'm using PS 7.01 and there isn't a box pop up. Helene > I come to a similar result differently, by using a copy of the > background layer after switching to 8 bit, often in soft light mode, > and then erasing the parts of the layer that produces effects I do > not want. Also, rather than use the burn/dodge tool, I use a layer > set to soft light and medium gray (a box pops up asking if you want > to set it to medium gray after you choose soft light). Using that > layer, you can burn by setting the foreground color to black and > using the brush tool and dodge by using white as the foreground > color. The advantage over the burn/dodge tool is flexibility as you > have control over both the brush and opacity. (The opacity control > seems finer grained that that using the tool.) > [Non-text portions of this message have been removed]
