Paper loading problems with Epson 1280
2003-06-16 by Alan Zimmerman
Has any body out there had problems with the fine art papers not loading properly on the 1280? Only when I manually exert downward pressure on the paper at the print start command, does it load. Then, sometimes not correctly. Problem started suddenly 2 days ago after perfect performance for previous year.
Any suggestions or work arounds?
Alan Zimmerman
  Sent: Monday, June 16, 2003 7:45 AM
  Subject: Re: [Digital BW] OT - PS7 Very Slow Loading
  This is probably more of a computer problem than a PS problem. Myself
  I've never understood why photoshop takes so long - I suspect it is a
  dinosaur that needs to be completely rewritten which will probably never
  happen.
  What I think you probably saw was an OS problem. Windows after it has
  been up for a long period of time - especially if you have run
  applications that require a lot of memory - will get corrupted and many
  things will not be done correctly. Windows memory management is not very
  good. A reboot will solve the problem.
  This is the very reason that although we have tried many times in the
  past to use high end PC for digital signal processing applications
  Windows always fails because of system reliability. The only way we have
  ever gotten them to work is by throwing away Windows and using Linux.
  Truman
  Kip Babington wrote:
  >Is there a common reason why Photoshop 7 should all of a sudden take an
  >extraordinarily long time to load, and sometimes fail to load at all?  It
  >was doing fine this afternoon, but this evening when I tried to open it (to
  >do some B&W prints using Lyson Quad Black on my Canon S9000) I've had it
  >fail to load several times and on another occasion took about 4 minutes to
  >load (felt like a half hour, of course.)
  >It has always taken longer to load than any other program I use, but I can
  >see that it loads up a ton of stuff at the start - I watch the items flash
  >by on the startup screen.  But this evening there are several places where
  >it seems to get hung up on a plug-in - I remember Bas-Relief sat on the
  >screen for what seemed like forever, and there were several others where
  >the loading process just seemed to stop for a while.  Eventually it
  >finished and my image manipulation seemed to work at normal speed, but
  >clearly something is wrong.  I didn't do anything particular to the
  >computer that I can remember - I just have Eudora and Internet Explorer
  >open most of the time.  I don't leave Photoshop open all the time, just
  >open it when I'm ready to do some image work.
  >Anything obvious to check to get back to "normal?"
  >Thanks for any ideas.
  >Cheers,
  >Kip
  >Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
  >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
  >If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
  >Please follow these basic guidelines:
  >- Include your full name with your message.
  >- Include the address of your website, if you have one.
  >- As threads develop, trim off excess portions of earlier messages to keep them short.
  >- As the topic of a thread changes remember to change the subject header.
  >- Good manners are required at all time. No personal attacks or flames
  >- Complete your Yahoo profile.
  >- Before posting a question, search the message archives and the various resources on the homepage.
  >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
        Yahoo! Groups Sponsor
Re: Paper loading problems with Epson 1280
2003-06-16 by cschaible94111
Alan:
This is a common problem.  The solution is to put some backing behind
the sheet to be printed.  The best way to do this is to get some 3/8
foamcore cut to the size of the sheet you are using.  (Better still,
foamcore cut to 11x13 will support both 11x17 and 13x19.) You can
also use four or five pieces of thin cardboard of the sort that comes
with many packages of paper.  (I do this for 8.5x11; just tape them
together.)  If you're wondering why this works, I really don't know,
but it always does.
Chuck
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Alan Zimmerman"
> Alan Zimmerman
>   ----- Original Message -----
>   From: Truman Prevatt
Myself
is a
probably never
>   happen.
has
and many
not very
applications
we have
Linux.
>   Truman
take an
all?  It
open it (to
I've had it
minutes to
but I can
items flash
places where
on the
others where
it
speed, but
Explorer
time, just
>   >Cheers,
>   >Kip
is at:
subject header.
flames
is at:
header.
flames
Service.
