Re: [Digital BW] Re: Paper loading problems with Epson 1280
2003-06-16 by Alan Zimmerman
thanks, I'll give the backing a try. Alan
Sent: Monday, June 16, 2003 11:14 AM
Subject: [Digital BW] Re: Paper loading problems with Epson 1280
Alan:
This is a common problem. The solution is to put some backing behind
the sheet to be printed. The best way to do this is to get some 3/8
foamcore cut to the size of the sheet you are using. (Better still,
foamcore cut to 11x13 will support both 11x17 and 13x19.) You can
also use four or five pieces of thin cardboard of the sort that comes
with many packages of paper. (I do this for 8.5x11; just tape them
together.) If you're wondering why this works, I really don't know,
but it always does.
Chuck
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Alan Zimmerman"
<azimmerman1@c...> wrote:
> Has any body out there had problems with the fine art papers not
loading properly on the 1280? Only when I manually exert downward
pressure on the paper at the print start command, does it load. Then,
sometimes not correctly. Problem started suddenly 2 days ago after
perfect performance for previous year.
> Any suggestions or work arounds?
> Alan Zimmerman
> From: Truman Prevatt
> Sent: Monday, June 16, 2003 7:45 AM
> Subject: Re: [Digital BW] OT - PS7 Very Slow Loading
> This is probably more of a computer problem than a PS problem.
Myself
> I've never understood why photoshop takes so long - I suspect it
is a
> dinosaur that needs to be completely rewritten which will
probably never
> happen.
> What I think you probably saw was an OS problem. Windows after it
has
> been up for a long period of time - especially if you have run
> applications that require a lot of memory - will get corrupted
and many
> things will not be done correctly. Windows memory management is
not very
> good. A reboot will solve the problem.
> This is the very reason that although we have tried many times in
> past to use high end PC for digital signal processing
applications
> Windows always fails because of system reliability. The only way
we have
> ever gotten them to work is by throwing away Windows and using
Linux.
> Truman
> Kip Babington wrote:
> >Is there a common reason why Photoshop 7 should all of a sudden
take an
> >extraordinarily long time to load, and sometimes fail to load at
all? It
> >was doing fine this afternoon, but this evening when I tried to
open it (to
> >do some B&W prints using Lyson Quad Black on my Canon S9000)
I've had it
> >fail to load several times and on another occasion took about 4
minutes to
> >load (felt like a half hour, of course.)
> >It has always taken longer to load than any other program I use,
but I can
> >see that it loads up a ton of stuff at the start - I watch the
items flash
> >by on the startup screen. But this evening there are several
places where
> >it seems to get hung up on a plug-in - I remember Bas-Relief sat
on the
> >screen for what seemed like forever, and there were several
others where
> >the loading process just seemed to stop for a while. Eventually
it
> >finished and my image manipulation seemed to work at normal
speed, but
> >clearly something is wrong. I didn't do anything particular to
> >computer that I can remember - I just have Eudora and Internet
Explorer
> >open most of the time. I don't leave Photoshop open all the
time, just
> >open it when I'm ready to do some image work.
> >Anything obvious to check to get back to "normal?"
> >Thanks for any ideas.
> >Cheers,
> >Kip
> >Please visit the Group Homepage to check the Files, Bookmarks,
Polls and other resources as they are often being updated. The page
is at:
> >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> >If you wish to receive no emails or just a daily digest, or you
wish to unsubscribe, please edit your Membership preferences by
visiting this same page.
> >Please follow these basic guidelines:
> >- Include your full name with your message.
> >- Include the address of your website, if you have one.
> >- As threads develop, trim off excess portions of earlier
messages to keep them short.
> >- As the topic of a thread changes remember to change the
subject header.
> >- Good manners are required at all time. No personal attacks or
flames
> >- Complete your Yahoo profile.
> >- Before posting a question, search the message archives and the
various resources on the homepage.
> >Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> Yahoo! Groups Sponsor
is at:
> - As the topic of a thread changes remember to change the subject
header.
flames
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
