Re: [Digital BW] OT - PS7 Very Slow Loading
2003-06-16 by Truman Prevatt
This is probably more of a computer problem than a PS problem. Myself
I've never understood why photoshop takes so long - I suspect it is a
dinosaur that needs to be completely rewritten which will probably never
happen.
What I think you probably saw was an OS problem. Windows after it has
been up for a long period of time - especially if you have run
applications that require a lot of memory - will get corrupted and many
things will not be done correctly. Windows memory management is not very
good. A reboot will solve the problem.
This is the very reason that although we have tried many times in the
past to use high end PC for digital signal processing applications
Windows always fails because of system reliability. The only way we have
ever gotten them to work is by throwing away Windows and using Linux.
Truman
Kip Babington wrote:
>Is there a common reason why Photoshop 7 should all of a sudden take an
>extraordinarily long time to load, and sometimes fail to load at all?  It
>was doing fine this afternoon, but this evening when I tried to open it (to
>do some B&W prints using Lyson Quad Black on my Canon S9000) I've had it
>fail to load several times and on another occasion took about 4 minutes to
>load (felt like a half hour, of course.)
>It has always taken longer to load than any other program I use, but I can
>see that it loads up a ton of stuff at the start - I watch the items flash
>by on the startup screen.  But this evening there are several places where
>it seems to get hung up on a plug-in - I remember Bas-Relief sat on the
>screen for what seemed like forever, and there were several others where
>the loading process just seemed to stop for a while.  Eventually it
>finished and my image manipulation seemed to work at normal speed, but
>clearly something is wrong.  I didn't do anything particular to the
>computer that I can remember - I just have Eudora and Internet Explorer
>open most of the time.  I don't leave Photoshop open all the time, just
>open it when I'm ready to do some image work.
>Anything obvious to check to get back to "normal?"
>Thanks for any ideas.
>Cheers,
>Kip
>Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- Include your full name with your message.
>- Include the address of your website, if you have one.
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- As the topic of a thread changes remember to change the subject header.
>- Good manners are required at all time. No personal attacks or flames
>- Complete your Yahoo profile.
>- Before posting a question, search the message archives and the various resources on the homepage.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-06-16 by Editor P.O.V. Image Service
>happen.
That's generally a problem only with versions of Windoze built on the
Win9X Kernel.. Win NT and its successors generally do not have this
problem...
It's called a "memory leak" and is a real pain in the butt with any
Win9x or WinME installation.
Keith
"Just some guy," and caretaker of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSON_Printers/
"For the rest of you out there, the secret is to bang the rocks together
guys"
2003-06-16 by Clayton Jones
Yeah, gray goo dripping down the side of the box.  Eccch!  Really
messy.
But if you rub it on your prints it increases Dmax and acts as a
preservative.  <ggg>
Clayton
NT suffers from OS memory leaks and a some point you will either crash
or have to reboot. In order to cut cost on a large signal processing we
were task to rehost the S/W from Sun's to an Intel platform. One time
software cost would very quickly be paid for considering the number of
units. In order to maintain compatability (and support upgrades) the
kernel siganl processing code was just recomplied. There were no leaks
in the applications on the Suns nor the Alpha  both running their
versions of Unix. About 1000 different people are beating on this code
daily and it also runs in real time 24/7 operational systems and is very
stable.
The S/W engineers could never get it work properly under any Windows
verson and the decision was eventualy made to go to Linux. Works fine.
The windows memory management still has a ways to go. There was some
desire to relook at the Windows environment but the decision was made to
simply load the windows emulator on the Linux box if someone just had to
run word or excel. That works fine to.
Truman
>>happen.
>problem...
>Keith
>Publications), at:
>guys"
