Re: [Digital BW] color or quad inks to test 1280 (to Jack)-thanks
2003-06-20 by Jack M Kucy
Thanks a lot. Jack _________________________________________________ Jack M Kucy JMK Gallery (www.jmk-gallery.com) 917-991-2096 jmk@... Member of ASMP (www.asmp.org) _________________________________________________ ...a riveder le stelle Antonis Ricos wrote: > > And now lame question. The printer comes with color cartridges (not > > loaded). Should I try it with the color inks to check if it works > fine, > > use the cleaning cartridge and put in the quad inks - or it's better > not > > to dirty the printer with the color inks, but go directly to quads? > > Thanks in advance, > > Jack > > > > Jack, > > you'll get peace of mind using the color inks to check the printer and > align the > heads. The latter cannot be done as well with gray inks anyway. > Since you have cleaning carts, you'll know when all color is out. > > > Antonis > [Non-text portions of this message have been removed]
