Re: [Digital BW] Square images on the monitor...
2003-06-23 by Anthony Atkielski
Jack writes: > On every CTR monitor any resolution you chose in > the driver will fit the screen, no matter if it's > in the screen proportions or not. Most screen resolutions produce square pixels if the display aspect ratio is 4:3 (the usual case). There are a few exceptions, the most notable of which is 1280x1024. > I like the resolution of 1280x1024 on my LaCie 19" > electron blue IV. To have the square images > appear square on the screen I had to adjust the > horizontal dimension of the display resulting with > about half an inch black strips on both sides of > the display. That's about all you can do, if you really want to stay at that resolution. > Flat panels work a bit different since the pixels are imposed by the > hardware, so all the screens show the square images square. Flat panels don't really know what the horizontal resolution is, if the usual analog connection to the video card is used, so I don't see how they can make any automatic adjustments.
