1160 waste pad changing time
2003-06-24 by Paul Roark
I just had my 1160 flash all its lights at me.  I assume this is a required
cleaning shutdown.  So, I used the counter reset procedure at
http://www.mwords.co.uk/pages/printers/printersHowDoI.htm#ResetPrinter
and it worked fine.
However, assuming it probably is time to change the waste ink pads, does
anyone have a URL for a good procedure for doing that?
Thanks.
http://www.PaulRoark.com
Re: 1160 waste pad changing time
2003-06-24 by Ron Norman
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul
required
esetPrinter
> and it worked fine.
pads, does
> Thanks.
> Paul
I just copied the following from MIS's web pages, I see that the
URL didn't come throught thought but go to the MIS site and look
under "News" and it about the 6th one down I think.
"April 9, 2003 - Epson Service Manuals and Adjustment
Programs
All Epson owners should have the Service Manual and
Adjustment Program for their printer. It is an invaluable resource.
Now they are available from our Russian allies for about $10 US.
We are sure Epson is not too pleased about this website, but it
is out there and we felt obligated to let you know about it. Go here
to get your Service Manual. We also put a link to this site on our
links page."   From MIS web site.
I purchased a manuel from the site and was pleased with the
service.  I saw the procedure in there but have read that the inks
dry out pretty fast and most times you can go another round
without gettig an ink over flow.   Ron Norman
If you like I'll look it up and send it to you...its a little
lengthly and will send it off line.
however.  Would suggest you get the manuel before it
disappears.
